Author Topic: golf edition 30 install a sub with a standard RNS310 unit  (Read 3857 times)
Offline azzii1992
« on: July 21, 2015, 01:36:30 pm »
Hello guys. First post here apologies if it's in the wrong place. I have fitted an RNS310 unit and want to fit a sub. The sub is fitted in a stealth box to the left in the boot. I have everything I need including a line out converter. I chose the vibe one as it has a built in remote cable so no need to find an ignition live feed. Now I've fitted all the wires on this loc to the rear of head unit so all the rear speakers left and right. Also have fitted the remote cable straight back to the amp and ground the earth to a screw on the rear chassis of the head unit. Now for the live 12v feed. What do I connect to I have tried scotch locking it to the positive fees on the back of the RNS310 but still no joy being able to power this amp. I have the power cable from battery with a 30amp fuse to the amp. Also ground the amp to a bolt under the front seat. Also have the speaker wire to the sub. Amy ideas where I am going wrong? Why I cannot get power to this amp? I even tried my mates amp and that does not power wither. Any help will be appreciated guys.
Offline azzii1992
Re: golf edition 30 install a sub with a standard RNS310 unit
« Reply #1 on: July 21, 2015, 01:47:28 pm »
I'm located near Newport south Wales if anyone can give a helping hand I got ££££ and beer. Haha :popcornsoda:
Offline xjay1337
  • -Receive: 377
« Reply #2 on: July 21, 2015, 01:52:35 pm »
to power my amp I ran a cable from battery to boot.
Switched ignition live. easy. Turns on and off with ignition.
If it's not powering then obviously you have no power... so it's a wiring fault. Take power from battery but use the switched live to turn it on/off etc.
I'm sh*t with wiring, I get my mate jairm to do it for me. im fine with mechanical stuff but electricity is like women, cannot be comprehended.
Offline Ricky123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« Reply #3 on: July 21, 2015, 01:55:33 pm »
Red thicker wire with inline fuse should go from battery to amp with the fuse closer to the battery end.
Black earth wire, make sure it's a good connection. A lot of the time you may need to remove paint from under the bolt your using for it to get a good earth
12v remote wire (normally blue) this switches your amp on. These normally receive power from the headunit but I don't think there is anywhere on the factory stereo. Best place I found to use last time was to run the wire to the 12v cigarette style boot socket and splice it in so when your ignition is on the amp will turn on.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline azzii1992
« Reply #4 on: July 21, 2015, 02:17:03 pm »
Ah right so I'm assuming the wire I locked into on rear of the head unit obviously isn't the live feed. The remote cable is on the line out converter. So it finds power with the small red cable and small ground and the that's the remote so it picks up when the speakers turn off. It's a new line out converter. Got all serrated wires for the amp see. Regards
Offline robmcclel
« Reply #5 on: July 21, 2015, 04:32:22 pm »
The remote cable doesn't have anything to do with the speakers. The remote cable needs to go to an ignition switched wire for example the 12v socket feed wire in the boot or the one in the ashtray. The red wire wants running through the car to the battery and the black wire wants to go to an earthing point. then you need to connect the rca in on the amp to the speaker outputs on the radio using the line out converter.
Offline Ricky123
« Reply #6 on: July 21, 2015, 05:10:20 pm »
As above ^^^
Remote cable needs a 12v feed to turn the amp on. A speaker wire will not give that.
I think you talking about an RCA adapter that basically splices In to your speaker wires to allow rca cables to be plugged in and get sound. That again shouldn't need a 12v feed? Well atleast I've not seen ones that do.
59 red mk6 GTi 5dr
Offline azzii1992
« Reply #7 on: July 21, 2015, 10:47:15 pm »
 :notworthy:well this line out converter has a built in remote cable that states it does not require an ignition live feed this us what I'm confused about. Off to see an audio specialist tomorrow and see what advice they can offer me
Offline Ricky123
« Reply #8 on: July 21, 2015, 10:49:40 pm »
Unless it's got a 12v feed from somewhere itself then it won't turn the amp on if the remote wire goes to that.
Splice your remote wire into and ignition live like the cig lighter. Use the adapter as a normal rca converter, red wire to battery, Earth the black one and it should all work fine.
59 red mk6 GTi 5dr
Offline azzii1992
« Reply #9 on: July 21, 2015, 11:51:05 pm »
Well can I run the power on the loc to the cig lighter then ground it to back of head unit then the remote will then turn amp on and off with the cig lighter power. Regard
