All Things Mk5 > How to Guides / Troubleshooting
Mk6 heater control issue help
<< < (3/3)
mo:
--- Quote from: Shoduchi on August 07, 2015, 07:36:09 pm ---Not having a direct fit frame puts me off this retrofit as well. I like things to look tidy. With some customization it's possible to fit it and later paint the frame and centre vents to look good, I know. Too much work in my opinion, so I forgot about it. :indifferent:
--- End quote ---
Same here. Though i will probably attempt it should some cheap parts appear on ebay or a ready made frame becomes availible which im sure will do eventually.
waj27:
Great help
Ma22789:
--- Quote from: mo on August 07, 2015, 04:23:37 pm ---I have heard in that the late MK6 Convertible panels are supposed to work
http://www.mk5golfgti.co.uk/forum/index.php/topic,79815.15.html
The Passat B6 panels also work and have the same wiring as the MK6 panels a lot of the guys have fitted to their mk5's.
The MK7 panel looks the same as the late MK6 convertible but will not work.
@Ma22789 Whats your part number ? According to the following thread the pn you need is 3AD 907 044 G (Passat B6)
http://vw-golfclub.ru/forum/showthread.php?t=42611 (russian site so run through Bing Translator)
According to this Vortex thread some extra pins may need connecting
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed
Pay attention to where it quotes the following:
Climatronic Wiring
On A Connector (black) extract both; Pin 16 and Pin 20 and put Pin 16 on the place were Pin 20 was, leave the wire on Pin 20 loose (not connected to the harrnes) for later connect the Air Quality Sensor if needed.
If you have an older VW Model you will MIGHT need this wiring change ATTENTION: Please don“t quote me on this, I just really followed some threads on VWNAVI that mention this change. It did not applied in my case)
Motors in parallel:
On C Connector (brown): Pin 7 connected to Pin 10 and Pin 8 connected to Pin 9
On B Connector (black): Pin 6 to Pin 7
--- End quote ---
That's my part number it came from a 2013 maybe 14 convertible golf r I tried the pin swap from connector A but still no good and sorry for the late reply I have been away
Pashka:
I have seen mk7 climatronic in b6 07-08 passat so it should be possible
To do that.
mvb12:
@Eddie-NL can you shed some light on this at all?  :popcornsoda:
Navigation
[0] Message Index
[*] Previous page
Go to full version
