All Things Mk5 => Mk5 General Area => Topic started by: AjayB on October 31, 2011, 06:47:59 pm
I have a little problem with my Golf Mk5 Gt Tdi, its been lowered by 35mm with H&R springs but now its scraping on anything and everything.. even on uneven road surfaces im getting contact. I didn't think this amount of drop would cause problems? anyone else having/had these issues?
I have the H&R Cup kit on my GT tdi and its fine are you sure they have not sent you the other springs that lower it 45/55mm??
Darren
The box and product code on the box match up to 35mm, will the springs have the drop marked on them? (I.e 35mm or 45mm).. might have to get one of the springs off to check..
Cheers, Ajay
Cheers, Ajay
I don't think they do but maybe wrong??
Darren
I've got the H&R 35mm springs on mine and it doesn't scrape on anything. What size wheels do you have? If they are quite small with a low profile, that would be your problem :scared:
Take a side on picture of your car! Im on springs thats done roughly 35mm ish with no problems!
These are the best pictures i have so far, i'll take some more clear ones tomorrow. For the size of the wheels i am running 18's.. this scraping is getting hard to live with tbh :sad1: Bare in mind the last picture is parked on the slight lift on the path on the passenger side but only small as you can see..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1081.photobucket.com%2Falbums%2Fj355%2FAjaybhatoa%2Fphoto.jpg&hash=a920c109326b3fa9787b48273896333b31b641b8)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fj355%2FAjaybhatoa%2FIMG_0537.jpg&hash=eebc102b03908354218e98de6282a5ff29c2d375)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fj355%2FAjaybhatoa%2FIMG_0493.jpg&hash=37a0a14825961df7e236e33d6d9c0b5038b86092)
what's scraping mate the wheels? Are they the correct offset? You're car doesn't look that low that it would make contact with the road....
Have you tried the arch screw mod? Thats supposed to help :smiley:
That'd be a good start if it's scraping on the front :happy2:
I think the offset of these are ET45.. sorry guys whats the screw mod? :scared:
On the front arches there is a screw holding the plastic liner to the metal arch take the screw out and fold the plastic back a fraction, I also bent the metal tab out of the way.
If you feel or look under the front arches you'll see the screw
Darren
Hmmm, that could actually be the answer. Ill go out now and check :party:
Actually before i check are they torx screws? i havent got any at home so will have to go buy some lol
The wheels im running are 18x8.5 ET45 (i think there that size!)and i dont get any scrubbing
dropped 35mm and the gt-tdi is lower then the 1.9 as standard, yet my car with 40mm looks lower sat on 15" steelies, ( not car lower , arch gap lower/less )
how can that be right unless i am mistaken!!
either way, unless you have strangely wide wheels with a crazy offset, i wouldn't expect rubbing, seeing as GTI models came with 18" alloys (i think) so your car running 18" should be - no problemo!
I'm thinking of just removing the 18's and the springs and going back to the original setup as its really annoying me :( cant quite find what the problem is... Awesome GTI said they think the shockers might need upgrading to some better ones but i dont want to spend that much money on the suspension just yet.. i even removed a little bit of the front undercarriage when it was down at Awesome to get the remap. These wheels atm are 18x8 ET45.
Is the undertray needed on my car? i might take it off tonight to try stop the scraping im getting! :( Grr! sorry to be bring this thread back up after a few weeks!
What is scraping, the tyres in the arch when turning or the bottom of the car on the road or even the tyres in the arch when driving straight?
Ftw, dont know how thats scraping mate. This is mine wound fully down on coilies and i get nothing. I can even drive over speed humps and get nothing. (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1183.photobucket.com%2Falbums%2Fx463%2Fgazon69%2F030c499c.jpg&hash=9fa5586110a1a77c9b0bad486767184664121da1)
Fella whats exactly scraping?
Does it Scrape over speed bumps? When Turning your wheels? With weight in the back?
Mines dropped around 60mm all round... Running 9J rears.. ET35... and ive got no scraping...
Most likey the the plastic undertray.. seems to have two protruding plastic edges either side that usually catch on raised road surfaces... Ive just sanded them down..
What are you running gazzon69?
To be honest i think it probably will be the undertray.. lined it up against my mates gti today and it looks as if my undertray is hanging rather low! Seems to be scraping on the left side more that the right though :S Happens over speed humps anything over 5mph and on uneven road surfaces.. i still need to do the screw mod under the front wing as i don't know if its rubbing slightly on that also when i hit uneven road surfaces.. If it is the undertray, should i replace it? or just remove it and leave it without one
Don't give up mate, you will find the cause! Maybe get the car up on some ramps and have a look. The undertray might have come loose and is hanging down scraping the road.
Hi mate are you okay in me arranging my own courier?
If so, I'll take it.
