All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: jimk04 on January 22, 2012, 04:25:19 pm
I have started on my BBK - I dont want to tread on the toes of Dave the brake Guru - I just fancy having a go at things myself.
These are the basis of the conversion so far - Mercedes 330x28 drilled. They have an overall height of 46.5mm. They are very reasonably priced - although they are not coated so I will be having to prepare the areas that the pad wont work against to keep them looking nice.
I have offered up a template of a 996 pad and they seem to cover the friction area perfectly - the pad just meets with the machined area on the inside, so I shouldn't have a rusty strip.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0256.jpg&hash=e565013dd37e6619c88792cad0579f83f5c0aafa)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0258.jpg&hash=2363b69bb79243b510720038ad831d08005ec70a)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0259.jpg&hash=b115e11118c6768946eb14ecd49562d6878a2be1)
Took them to my local machine shop and they are going to take out the centre bore a bit more - then make a spigot to fill back in again to the 65mm dia. of the VW hub.
Will be a while till I can afford calipers but atleast I can make a start on the discs. Think I will drop them in this week for machining.
Discs are now back from machining - we took the centres out in diameter then made up some stainless spigots. They fit a treat!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0265.jpg&hash=4e6094eda3d3de2a1e70f1284ddce2fa5c943de9)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0264.jpg&hash=eb6b82d436d0e85232adb2806b8fe348438598a4)
Time to paint them now and hunt for some calipers!
:popcornsoda:
:popcornsoda:
x1
:happy2: :congrats: :happy2:
Jesus buddy! Making your own BBK is something to be proud of! Well done and keep us posted :drinking:
Thanks all for the kind comments
Discs are painted so will put some pics up soon, and I have sorted a pair of 996 fronts that need a refurb for decent money so that is good for me as I like to tinker!
will soon be time to get the machine shop to do me some carriers! :party:
do you have a pattern for the caliper carrier or did you just make your own measurements?
im considering a BBK but finding the brackets etc is putting me off.
Ask Dave. He maybe able to provide this as well.
asked him a couple of times but no reply yet.
I've been struggling on replies for carriers etc too but then I came across this site http://www.porschecalipers.co.uk/uk/index.html
I emailed the bloke who really seems to know his stuff so if you need any bits for doing a BBQ hes very helpful and not badly priced either, he'll have stock of the 312 brackets in the next week or so, and he does brackets for larger sizes too.
@ Viken; I dont have a pattern but the machine shop I use are very good and said they could make me some up from scratch if I just take the hub/disc/caliper along to them. Or I may draw one up on CAD if I get the time.
I have the experience and resources to have a go at this but I would reiterate that if you are unsure about any of it then employ the services of a chap like DaveB to sort you out....you dont get 2 chances where brakes are concerned!
Full marks Jim....
And full marks again for realising these are brakes and need a good coat of looking at.
I've got a drawing for that carrier if you need it, all the carriers you,see on eBay and other sites are direct copies of mine that I've supplied over the years, it got to the stage where I wouldn't supply to anybody with a Leicester postcode.
Thomas's site has come on a lot, he was a member over on uk-mkivs and I've supplied him some stuff in the past we were forever bidding on the same stuff on the bay!
You'll need a healthy wheel spacer for that setup but that said there a massive sense of achievement for running something you've put together yourself, built not bought springs to mind.
I even considered having some discs commissioned at one point, hydraulically there no benefit in running these over the NQSBBK except a little thicker disc and a slightly larger pad little bit heavier too....aren't they...!
if you need any help at all pal give me a ring, gonna pm you my mobi over now.
if anybody is struggling getting hold of me please keep trying, I get like 40pms a day, say 3 mins a pm to think and reply that's two hours a night on top of my day job and actually getting the stuff made!
Website goes live very soon tou'll all be pleased to hear you'll be able to buy online
I thought this might have been you http://www.porschecalipers.co.uk/ (http://www.porschecalipers.co.uk/)
DAVEB1970, sent you a couple of PM's. i know you must get loads! :happy2:
just wanted a price for the brackets, bolts and hoses or everything required to fit the boxster calipers
also do you have any calipers to sell already refurbed and painted?
if not how much would it be to refurb/service calipers i buy from a breakers etc?
cheers
Thanks for that Dave, means a lot coming from the brake daddy!
I am a little concerned about the spacer that I will need to clear them, especially as I have some TT arms to go on which as we all know push the lot out even further..... :confused: We will see!
Quick update
Bagged these off ebay for £33! Should be fine for me.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0269.jpg&hash=136cd52abb5267594b431852e35bd7fe8bf300fa)
Also been measuring up for adaptor brackets - disc here is in the zinc primer stage!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0268.jpg&hash=87bca0189485e4dc813f66523ae83c01d51423d5)
And one finished disc after a coat of VHT aluminium and a bake in the oven at 200deg C!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0272.jpg&hash=fb6510c93df1dd3a55ff30280aab660fbcf59d64)
I have ordered the pad wear sensors - interestingly, the earlier type of sensor has the correct plug to fit straight onto the mk5 loom, but the later pin type that I need have a different plug, which will need chopping off and a new one soldering on.
Also been looking into the flexi hoses. To save some money I may use some off the shelf rubber ones, as the R32 and some Touerag have the requisite M10 banjo fitting and seem to be a suitable overall length.
Hopefully the calipers will show early this week!
Hi Jim,
Great to see someone doing a DIY brake kit, kind of thing I spend hours thinking up/building. Can I ask what you do for a job? Guess you are in automotive / engineering trade?
Errr.....I'm a gardener/estate keeper! :grin:
I have always been into serious DIY car stuff tho and did engineering HNC at college many moons ago!
Jim before you make them look too pretty, drill yourself a M6 countersunk hole at 36 degrees if you know what I mean, you also need to countersink it.
also just check the bolt holes and make sure they M14 I think when I looked at it they were M12 and needed drilling out.
Got some used HEL lines here off an PX kit you can have they just need a clean up
Regarding the carriers, don't forget you'll be mounting these from the back I guess that's to say the bolt might well be pointing towards the engine as opposed to the other way. Of course you have S3 hubs so there's another 16mm to find so it's going to be a fairly large bracket. Might be worthwhile having your machine shop have a carve at a lump of aluminium first for mocking up purposes refining the measurements and then beefing it up in aluminium you end up making three carriers but Ali is cheap and 60% ofthe time to machine
if you bought cayenne rear pads then you'll be able to find a suitable wear sensor from a tourag, the rear pads from a 4x4 might not perform as well as dedicated Porsche fronts....the weights on top of the pad make me think they're cayenne rears, 996 fronts don't have the weights and use pad dampeners which are the same as cayman s ones which are cheaper.
All looking good though.....missed your last Pm, hoses are FOC, get in touch you've got me mobi
Edit you need M10x1 swivel fitting NOT banjo for 996 fronts
Cheers for the input again Dave. Pads are definitely 996/boxster s fronts. States on the box and they were sealed.
My bad RE- banjo fitting. Guess it would have soon become obvious when I actually get my calipers!.
May well take up your offer on the flexis. Will sort you out....also did you get my pm re bracket price/drawing?
Jim
My carriers and the ones on ebay are GTI versions and NOT S3 brackets, they are quite different, Im almost certain you'll need to point the carrier from in to out so it will be a wide bracket thats for sure.
So you're pioneering!
I've got a NQSBBK caliper carrier attached to Mike TFSI's old calipers, thats derived for the boxster front but the centres are all the same at 130mm for the calipers, ask him to send you a pic of it for some inspiration, from memory the lugs to attach to the S3 hub need to be a peculiar shape to miss some part of the casting. The boxster caliper is narrower than the 996 so that means that means the holes for the calipers will be different
Jim
Remind me tomo jim and I'll take a couple of pics of the brackets 07935089 441
Respect to you buddy
Well a small update people - not done a huge amount with this recently.
But I have some calipers.....ugly ass things they are too.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0276.jpg&hash=57a63cd8c9577509c29141dae4040fa5b082ea50)
It gets worse!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0275.jpg&hash=a95cb5507acfcf7e1e5473d8383ea07fd2d641e3)
Been a bit warm this one, melted the rubber around the bleed nips, and smoke stain galore.... :surprised:
Luckily though - on removing the pistons there is no damage to the seals at all - all is well. I just damaged one dust seal removing them tho. All pistons moved freely which is nice.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0281.jpg&hash=85aeffce8df2781c6f5dfc9d661cdb84dd69d03d)
I offered up a caliper just to keep my enthusiasm going!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0278.jpg&hash=cccaebfc8e7d39f5f73bb13c720971412c247913)
Discs now drilled to clear M14 lugs, and for the disc retaining screw - although the latter took me a few attempts to line up... :ashamed:!
Dropping it all off at the machine shop tomorrow hopefully if my carrier and caliper bolts come from TPS. See if they cant knock something up without a drawing....I havent had time yet to CAD it up.
Will be on with caliper renovation soon I guess, need one dust seal, bleed nips/rubbers, and pad fitting kit.
Oh yeah I also got some 'AMG' decals, thought it would be a change from the usual 'Porsche' - and also a nod to the origin of my discs! I may concede tho and stick some porker ones on!!
update folks
Carrier is mocked up and seems pretty good - but it just needs to pull the caliper in about 3 or 4mm more as the pad is just overhanging a tadge. It was one thing I said to the machine shop that was critical but hey ho, they didnt charge me much at all.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0299.jpg&hash=263b680e9ceb788a81966f1b5d9323148a9f62e6)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0298.jpg&hash=df45ac157dcd28a691b962b6d6581c72e60b4d3a)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0297.jpg&hash=3267821acf2fb8c145ea4f0dc57da23570e88df3)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fjimk04%2Fmk5%2FIMAG0296.jpg&hash=7a213f364ad4ad3b252c9aaca1dcb1e1d343fba3)
You can see we did them mounting from the front so atleast you can get to the bolts with the disc on...not sure it this means they will fit the GTI hub aswell as the ally hubs...cant remember what Ive read about this!!
Had a play with a wheel and it looks like 12mm is the wheel spacer requirement....hopefully as that is what I have just ordered! My only concern is if 12mm spacer will work with the TT arms. May be too much.
Had a scary moment with a caliper today swapping the lines over, one had quite a bit of dissimilar metal corrosion and the M10 fitting has dragged some of the ally tread with it, but I think I have just gotten away with it... :ashamed: :scared:
Do you want my M10x1 tap sending as well!
Ok couple of comments if that is helicoiled Ali and I think I'm right in saying you need to take 3-4mm off the top surface then either use m12 x1.25 helicoils and bolts or convert to steel
M10x1 all sorted Dave thanks!
I am having the calipers machined down instead of the carriers - I didnt think there was enough meat left either!
Interestingly having looked at pics of 996TT calipers - they seem to be machined down a bit like what I am about to do. :popcornsoda:
Spacers are on aswell BTW. Not a massive difference in terms of looks and handling so thats all good.
The rest is here chaps
http://www.mk5golfgti.co.uk/forum/index.php/topic,38677.0.html
