Author Topic: Front Pad Upgrade  (Read 4979 times)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
Front Pad Upgrade
« on: December 19, 2009, 02:08:24 pm »
Guys,
If I upgraded the pads and the discs to these:
http://cgi.ebay.co.uk/Golf-mk5-GTi-Turbo-Drilled-Grooved-Brake-Discs-Front_W0QQitemZ300340107835QQcmdZViewItemQQimsxq20091118?IMSfp=TL091118178003r7810
http://www.volkswagenracing.co.uk/Golf%205%20Pages/Golf%20Brake%20Pads.html
- Can I continue to use the standard calipers?
In the next 6 months or so, I plan to upgrade the power with Revo stg2 and fit my ITG panel filter, nothing more.
I'm assume these brakes will be suitable?
I'm wondering if just the front pad upgrade on it's own would be sufficient?
Thanks,
Pete.
Pete
Offline QD MBE
  • -Receive: 102
Re: Front Pad Upgrade
« Reply #1 on: December 19, 2009, 02:12:08 pm »
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #2 on: December 20, 2009, 11:52:59 pm »
Cheers SB, I will do but not looking to purchase yet. I'll PM him anyway as I understand his knowledge of brakes is good.
In the meanwhile, would I have to bin the standard calipers or would the above all fit and be a fair setup for 250*hp on a very good day?
« Last Edit: December 21, 2009, 12:32:20 pm by rdfcpete »
Pete
Offline QD MBE
  • -Receive: 102
« Reply #3 on: December 21, 2009, 05:09:24 am »
In the meanwhile, would I have to bin the standard calipers or would the above all fit and be a fair setup for 2505hp on a very good day?
Not sure what remap you have........................... 2505hp!!!!!!!!!!!!!!!! :rolleye: :driver:
The pads Nath is selling will fit straight on, no caliper changes etc.
Give them a go, He thought they were very good on his Ed with 320Hp.
 :santa:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: December 21, 2009, 08:18:08 am »
depends alot on your planned usage of the car and your driving 'style'
you going to be doing any track days etc?
the good folks on here, recomended some pagid blue pads to fit the std 312mm discs, which by all accounts are great if you plan to go no further. or Nathans set on here that are also good value  :happy2:
But if you then decided they werent sufficient then its probably not a good investment.
going to R32 fronts (+ optional rears) , then up to proper big brake kits are steps up from that ....
I went for R32 fronts from DaveB on here, which performed faultlessly at Oulton Park.
the solution depends on your requirements :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #5 on: December 21, 2009, 12:40:42 pm »
 :santa:
 :laugh: :grin: Ooopps.
If they suited Nath with 320ps on a car of a similar weight, then that's all the assurance I need really.
I won't be track day'ing John so I don't need anything that's built for race performance. Purely Commuting and S+DP really with the few engine mods mentioned above.
Are the discs necessary too or not really given my driving style is generally moderate, i.e. will the VWR pads suffice on their own?
I don't know if Nath had standard calipers + discs?...
I don't think I can justify R32 fronts, cost and hassle for what I need.
Cheers John  :smiley:
Pete
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #6 on: December 21, 2009, 01:20:05 pm »
in which case Nathans pads are just  :happy2:
(yes he is/was running std discs/calipers the 312mm OE GTI setup AFAIK)
tbh given the way youve described it, the OE setup should suffice ?
Have you had fade issues on the road ? or are your current setup worn and need replacing?
Red ED35 5dr DSG
BLOG | BUILD
« Reply #7 on: December 21, 2009, 01:25:40 pm »
As already said Pete I ran these pads with standard discs and they performed really well in all circumstances.
(PS they were reigning in closer to 340bhp!  :wink: :laugh:)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #8 on: December 27, 2009, 04:37:45 pm »
Perfect Nath + fellas, they sound like all I need.  :smiley:
Not sure I'll be able to purchase anytime soon unfortunately by they're added to the growing to-do list  :congrats: Thanks.
Pete
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #9 on: January 24, 2010, 07:51:58 pm »
Nath,
Did you change the fluid at all or run OEM stuff?
Ty  :smiley:
Pete
« Reply #10 on: January 24, 2010, 07:56:49 pm »
Nath,
Ty  :smiley:
Factory fluid matey!  :happy2:
Offline olufsen
« Reply #11 on: January 28, 2013, 03:00:47 pm »
Do you still run these mTech discs mate?  How did you find them over time; still recommend them?
« Reply #12 on: January 28, 2013, 05:56:46 pm »
Holy thread revival!  :surprised: :laugh:
No mate, I only ran them for a few k and that was a few years ago.
