Author Topic: Stale smell when heathers on  (Read 1095 times)
Offline Northy1985
  • Instagram o_n02thy
« on: September 12, 2015, 06:55:34 pm »
As title says soon as I put the heating on I gets real nasty stale smell anyone had similar
Re: Stale smell when heathers on
« Reply #1 on: September 12, 2015, 07:08:22 pm »
Probably need the pollen filter changing
Offline Northy1985
« Reply #2 on: September 12, 2015, 07:13:58 pm »
Right ok I'm a new owner so all new to me are they easy to change or is that another pain in the arse job also best place to get a filter
Offline doylebros
  • -Receive: 310
« Reply #3 on: September 12, 2015, 07:39:11 pm »
Easy to change follow this to step 3 - when at step three you'll have the pollen filter in front of you (held in by one screw or none if the last person was lazy)!
Exploded photo at stage three and you'll see his pollen filter partially removed
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/78-BODY-Blower_Motor_Replacement/78-BODY-Blower_Motor_Replacement.htm
The filter is the bit above the plastic with two hooks - this bit plastic slides off the hook supports and the filter can be removed.
TPS is worth checking for a price.
Offline Northy1985
« Reply #4 on: September 12, 2015, 07:59:27 pm »
Lovely thank you i will get a filter and gove it a try hopefully the smell will go as its not very nice even with aircon going can smell it slightly
