Author Topic: Problems after ABS Pump Fix [FIXED]  (Read 18460 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Problems after ABS Pump Fix
« Reply #30 on: September 19, 2015, 08:59:57 pm »
Still remuging about for clues :)
Looks like Rosstech specifically state in the special notes area that if a WSS (wheel speed sensor) is not working then the steering wheel stop adaptation wont work:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation
Is there any way to tell whether its a bad sensor or the hub that needs doing before actually doing it?
Out of interest was the vehicle scanned before the ABS pump tear down if so was the wheel sensor faulty on that scan?
I test the ABS sensors with a multimeter and just compare the value to a working sensors on the ohms scale - this might help http://www.golfgtiforum.co.uk/index.php?topic=129702.0
On price check with TPS - in our area there keen to match Euro CP.
Looking back through my scans, yes it was mate... makes me feel better that it wasn't false due to the pump being split.  I just didn't notice because the dash has been lit up for ages. :ashamed:
INteresting to hear TPS will try and price match, as I'd definitely prefer OEM on this type of part. :happy2:
Offline biffobear
« Reply #31 on: September 20, 2015, 10:46:40 am »
You will be banging your head against the wall until you sort the reluctor/sensor problem, I have used rear bearings on ebay £30 for years with no problems, biggest ball ache is the bolts holding the brake caliper retaining bracket on, better done on a ramp using a long breaker bar to remove. Should find once this problem with the sensor is fixed, things will start working ok.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #32 on: September 20, 2015, 12:02:10 pm »
Here's hoping bud :)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Problems after ABS Pump Fix [FIXED]
« Reply #33 on: September 23, 2015, 04:56:44 pm »
Wednesday,23,September,2015,16:10:22:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: 51651651561561561   Mileage: 234410km/145655miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
MOT next :)
Offline biffobear
« Reply #34 on: September 23, 2015, 06:35:39 pm »
What cured it?
« Reply #35 on: September 23, 2015, 07:42:30 pm »
Hopefully the wheel sensor
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #36 on: September 23, 2015, 08:38:06 pm »
Sorry guys, should've mentioned that... Offside Rear wheel hub reluctor ring, then recalibration.  It would've all worked grand after doing the ABS pump if the Wheel Hub wasn't foobarred, as the Power Steering is linked heavily into the wheel speed, I thought it back here, but wasn't sure if it was the sensor or the hub.
After measuring the wheel speed from each side using VCDS measuring blocks... that Offside rear wasn't returning a value.  Cleared the fault, it didn't come back straight away... if the sensor was an Open Circuit then I would assume the sensor was at fault and return straight away.  It only returned when trying to read from the Hub reluctor ring whilst in motion, so I took this educated guess at it being the Hub at fault.
Replaced it + VCDS magic = Happy days. :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #37 on: September 25, 2015, 04:53:55 pm »
PASSED no advisories. :pomppomp:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #38 on: September 25, 2015, 04:57:35 pm »
Well done mate  :congrats:
05 | Tornado Red | DSG
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #39 on: September 25, 2015, 05:09:18 pm »
Cheers mate... bit chuffed truth be told :)
