Author Topic: Cam follower.  (Read 6643 times)
Offline Aparoon
Re: Cam follower.
« Reply #15 on: December 23, 2009, 02:04:31 pm »
It seems straight forward reading tthe how to... but, how do you set tdc on a dsg car? Also is this purely maintenance or is performance effected?
Edition 30 DSG, Revo 2+,BSH Intake, Autotech hpfp, Blueflame TBE,  Eibach Sportlines, Speedline Turini's GONE
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Cam follower.
« Reply #16 on: December 23, 2009, 02:06:42 pm »
It was rebuilt with K04 at 160.000 and i have just booked time in Jan for 180.000km service. I get it looked over every 10.00km after the rebuild, oil, oilfilter and camfollower  :happy2:
It's a car made to be used, what can i say  :laugh:
« Last Edit: December 23, 2009, 05:20:46 pm by danishmkvgti »
Over the top mod list ;o)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Cam follower.
« Reply #17 on: December 23, 2009, 03:25:16 pm »
It seems straight forward reading the how to... but, how do you set tdc on a dsg car? Also is this purely maintenance or is performance effected?
I would imagine TDC is the same on a DSG as it's setting the Cylinders to No.1 Top Dead Centre and nothing to do with the Gearbox. But i have never worked on a DSG engine.
It's a case of stripping off the Cam/Timing belt cover and rocking the car forwards or backwards in gear until the arrow at the side of the Biggest Cog lines up with the Arrow on the Cylinder head.
This has the effect of reducing the Tension Pressure on the Pump Piston so that when you put it back on you don't have to force it closed and risk bending/damaging it.
As i havent ever worked on a DSG engine someone like Stu,Hedge or Jonnyc will probably be able to tell you more.
Carl :happy2:
Re: Cam follower.
« Reply #18 on: December 23, 2009, 07:05:08 pm »
I think Stu is still cursing me after we fitted my pump.  :ashamed:
The problem on a DSG car is that you aren't supposed to move the car without the engine running.
Offline jonnyc
  • Herrooooo!
Re: Cam follower.
« Reply #19 on: December 23, 2009, 07:08:35 pm »
Love it! Awesome.. And just shows if you look after a motor well it will last and last!! Good work mate  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Cam follower.
« Reply #20 on: December 23, 2009, 07:11:29 pm »
So any tips on how to get to TDC following your fun with Stu  :laugh: :laugh:
Offline jonnyc
  • Herrooooo!
Re: Cam follower.
« Reply #21 on: December 23, 2009, 07:13:25 pm »
I have never bothered getting TDC before doing fuel pump / follower change.. All it means is that there is no preload on the fuel pump spring but so long as you remove the bolts evenly, and torque down carefully in diagonals then no problems..
Re: Cam follower.
« Reply #22 on: December 23, 2009, 07:15:20 pm »
Remove plugs, timing cover and anything in the way.
Stick big spanner (not me) on end of camshaft and turn to align the marks on the pulley.
I asked Jim @ JKM what they did and the answer was nothing.
All they do is apply even pressure on the pump and hold it straight while inserting the bolts.
PS. As Jonny said.  :happy2:
Re: Cam follower.
« Reply #23 on: December 23, 2009, 09:43:25 pm »
Did Mat not mention that the ED 30 cant get any lobe wear. I am sure he said they revised something for the Eddie.  :driver:
  • -Receive: 81
Re: Cam follower.
« Reply #24 on: December 23, 2009, 09:54:14 pm »
i was told its a not an ed30 problem due to the cams not being the same as the normal gti as the duration on the fuel pump is not long or something down those lines. This was vwr who told me this as they said they only see the wear on the stock gti and not on the ed30 as they noticed this when they did the red vwr car as the they changed the cams to the ed30 ones when they k04 the red car
Offline cmdrfire
    • Commander Fire - my blog
Re: Cam follower.
« Reply #25 on: December 24, 2009, 10:58:49 pm »
I've heard that 1) cam followers should be replaced with newer revisions and also 2) that AXX engines don't have this particular issue. Can anyone on this thread verify that for me?
Offline bacillus
  • -Receive: 451
Re: Cam follower.
« Reply #26 on: December 24, 2009, 11:43:23 pm »
Didn't some of the early GTis i.e. AXX come with an A revision softer lobed cam that was subsequently replaced by the more robust B cam together with an updated cam follower?
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Cam follower.
« Reply #27 on: December 25, 2009, 01:14:23 am »
.........mine is on an AXX code ?.
Offline pitsirikas
  • -Given: 19
Re: Cam follower.
« Reply #28 on: January 23, 2010, 06:55:10 am »
No more cam-follower replacements........?
http://www.h2sport.com/
                     Don't drive faster than your angel can fly..!
                Respect a man's car and the man will respect you
  • -Given: 243
  • -Receive: 154
Re: Cam follower.
« Reply #29 on: January 23, 2010, 07:23:38 am »
i bet you can buy multiple cam followers for one of those.
The TSI system applied to the TFSI though  :wink:
