Author Topic: 3dr Rear Speaker Upgrade - Gladen?  (Read 26562 times)
Offline Rob.
Re: 3dr Rear Speaker Upgrade - Gladen?
« Reply #45 on: November 04, 2015, 07:05:44 am »
Are the mid-bass attached to the plastic mounting spacer, or could they be replaced with plywood baffles?
Offline DANBOY66
  • -Given: 41
« Reply #46 on: November 04, 2015, 08:20:51 am »
i am also interested in the gladen one kit it looks a good piece of kit  :happy2:
would be good to see if we can get a group buy going to save a few pennies
Dan..
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #47 on: November 04, 2015, 01:27:53 pm »
You need the spacer. It's a much deeper woofer, would foul on the window regulator mech if not attached to spacer.
#1493
Offline Rob.
« Reply #48 on: November 05, 2015, 06:14:42 am »
I understand, but is the plastic spacer fully bonded to the speaker basket? Or could you easily remove it and make something out of wood instead?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #49 on: November 05, 2015, 08:24:40 am »
They are separate pieces. You attach the spacer to the door and then the speaker to the spacer.
#1493
Offline xjay1337
  • -Receive: 377
« Reply #50 on: November 05, 2015, 09:06:43 am »
Use the Connects2 speaker surrounds. Although they fit sh*te and you'll need to trim it down.
Online loop
  • -Given: 26
« Reply #51 on: November 05, 2015, 10:45:05 am »
My Rainbow speakers are 165mm, 100mm and 26mm. Do you think these would fit ok?
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline DANBOY66
  • -Given: 41
« Reply #52 on: November 05, 2015, 11:08:37 am »
have you seen the gladen one extreme kits for the mk5 golf exactly the same set up just even more power full  :happy2:
Dan..
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #53 on: November 05, 2015, 12:35:36 pm »
Just a different ohmage I think?
Offline DANBOY66
  • -Given: 41
« Reply #54 on: November 05, 2015, 02:10:53 pm »
ONE LINE 200, 3-way
Plug & Play 3-way System for VW
25 mm silk dome tweeter
4” shallow midrange
8” shallow woofer
4 ohm impedance
Incl. adapter plates & cable harnesses
2x 170/120 Watt
For Golf 5
Paper cones
Neodymium motors
Custom fit baskets
Crossover with 3 possible tweeter level settings
ONE LINE 200, 3-way EXTREME
4” shallow midrange
8” shallow woofer
2 ohm impedance
More powerful
Similar basket 200 slim
2x 225/150 Watt
For Golf 5
Paper cones
Neodymium motors
Custom fit baskets
Dan..
Offline Rob.
« Reply #55 on: November 05, 2015, 09:28:47 pm »
The Extremes are quite a bit more expensive too, sadly.
Online loop
  • -Given: 26
« Reply #56 on: November 06, 2015, 08:09:50 am »
What I intend to do is change the fronts, keep the rears OEM, and add an amp, all connected to my RNS 510. I don't know if anyone can recommend an installer/company in the south east who can help me with this??
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #57 on: November 06, 2015, 11:30:55 am »
TeamSPB but not sure where they are based.
#1493
Offline white91
« Reply #58 on: November 06, 2015, 12:24:35 pm »
Don't forget sound deadening
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #59 on: November 06, 2015, 04:32:13 pm »
Wasn't there a guy off mkivs that was pretty good, Imagewerx? Think he's dahn sahf anyway.
