Author Topic: Rear brake upgrade advice.  (Read 15724 times)
Offline jedi-knight83
  • -Receive: 41
« on: October 09, 2015, 04:57:20 pm »
So I've just bought some mk7 golf R brakes for the front.
Is it a good idea to upgrade the rears? Is it necessary? Or OK to carry on with the standard GTI rears?
Just wondering about the balance. Or do people only really do it for visual reasons.
Offline jacobrownoly
Re: Rear brake upgrade advice.
« Reply #1 on: January 23, 2016, 11:19:10 pm »
 :popcornsoda:
Offline gixerben
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92657.msg930393.html#msg930393
« Reply #2 on: January 24, 2016, 03:23:11 pm »
I'm just running TTS front brakes and standard rears at present, all seems ok but I'm always on the look out for an S3 rear set up. :wink:
Pirelli GTI
« Reply #3 on: January 24, 2016, 03:57:46 pm »
I'm running a BBK and OEM GTI rears.... No bother.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: January 27, 2016, 12:23:31 am »
I fell in love with the rear brakes vvv
Offline xjay1337
  • -Receive: 377
« Reply #5 on: January 27, 2016, 12:44:33 am »
bloody f1.8 prime lenses and their soft focus really irks me!!!
ANyway 4 pots on the back are for show rather than go most of the case
S3 calipers are all that you actually NEED combined with a decent ttrs setup up front
340/345mm on a ttrs caliper with the aks adaptors and whatever the s3 is (i forget is it 303 or 310 or 308 blah blah) will give you a lovely pedal and good even braking force which will hunker the car down into the ground.
Issue is after this master cylinder and long pedal
you'll need 6/8 pots up front to compliment a 4 pot rear. That's a lot of fluid
and a lot of cost
Once you go above the ttrs / s3 - front / rear setup the improvement tails off very quickly at great expense for that extra 5%.
even for most people on the track or in light competitions its not necessary.
notice how nearly all of the multi piston rear setups are on show cars that never go more than 30...  :innocent:
« Reply #6 on: January 27, 2016, 01:38:56 am »
and a lot of cost
thats mine Jay :signLOL:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #7 on: January 27, 2016, 11:12:40 am »
As long as your GTI has the same master-cylinder as the R32 (like mine has) you can have a 6 pot at the front and the R32/S3 brakes at the rear (310 mm vented discs instead of 282/286 mm solid discs) with great pedal feel. My Brembos 18Z at the front were cheaper to properly setup and I don't need wheel spacer with OZ Ultraleggeras. Just another option when considering brake upgrades. :smiley:
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #8 on: January 27, 2016, 12:18:05 pm »
Do you have any part numbers to differentiate between the two different master cylinders?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #9 on: January 27, 2016, 12:32:26 pm »
It's easy to check. The smaller has 22 written in the part and the bigger has 23. I could easily see that my GT Sport has a 22 and my Ed. 30 has a 23.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #10 on: January 27, 2016, 12:35:53 pm »
Cheers mate!
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #11 on: January 27, 2016, 01:01:10 pm »
Cheers mate!
Glad to help! :smiley:
Offline xjay1337
  • -Receive: 377
« Reply #12 on: January 27, 2016, 01:09:47 pm »
Offline skuncan67
  • -Given: 19
« Reply #13 on: June 03, 2016, 11:16:28 pm »
Hi r5gtt,
are you running 6 pots on the front and 4 pots on the back ?.... did you do the MC upgrade ?
thanks Duncan
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: June 04, 2016, 02:22:28 am »
Hi r5gtt,
thanks Duncan
Hi @skuncan67 Duncan, I wish they were mine but that was just a picture I found when searching for something. I have standard brakes atm and don't think I'm going to be replacing them anytime soon. funds are way too low. If I were to do a brake upgrade then it would only be the four pot as I did with my last car and the rears I'd most likely leave oem. Sorry I couldn't help.
Regards
R5gtt
« Last Edit: June 04, 2016, 02:29:24 am by r5gtt »
