Author Topic: Idle problems!  (Read 1510 times)
theface1987
Idle problems!
« on: October 09, 2015, 06:04:22 pm »
Evening people, don't know where to start here but to cut a long story short......
Started having a rough idle, I have the DSG mk5 just to make you aware, when I pull up at traffic lights or traffic for example, the car is jerking as a result of the idle up and down as if the engine is pulsating,
So new fuel filter
Major service at Volkswagen (notified me of a misfire)
Just fitted new bank of ignition coils
And still it's doing the same.
Also it's driving fine with full power, the issue only arises when I come to a standstill
I wish I could explain this better but I am not competent enough to do so!
Please help guys
Offline shoaybmakda
  • -Receive: 54
Re: Idle problems!
« Reply #1 on: October 09, 2015, 08:38:02 pm »
have you checked the PCV valve? common issue with the GTI's and solved my idle issue
5 minute job not to difficult to do it yourself if thats what needs replacing.
would also recommend getting it scanned with VCDS before buying any parts
Offline doylebros
  • -Receive: 310
Re: Idle problems!
« Reply #2 on: October 09, 2015, 08:46:30 pm »
As above plus check the air filter housing for cracks caused when removing!
theface1987
Re: Idle problems!
« Reply #3 on: October 10, 2015, 08:09:58 am »
Thanks very much, I'll have a look and change, my fingers are crossed!
Thanks again
Offline DomBacon
Re: Idle problems!
« Reply #4 on: October 11, 2015, 12:00:01 pm »
I have the same problem! I have a brand new pcv and dv!
Mine misfires on cylinder 3 and 4 only at idle!
Offline DomBacon
Re: Idle problems!
« Reply #5 on: October 11, 2015, 10:57:01 pm »
Know anywhere that cleans it all out?
Just hope it's not an injector otherwise it'll all be coming off again!
