Author Topic: Rcd 310 aux lead possible?  (Read 1494 times)
Offline Matthewsimone
  • -Receive: 39
« on: October 21, 2015, 05:08:58 pm »
Afternoon all
Just a quick one, wife has a 57 plate Gt tdi with rcd 300 unit installed
Is it possible to get a lead/cable to plug into back of the unit to allow us to play mp3 player and ipod etc?
Even just a 3.5mm headphone plug would be fine?
Looked at them on ebay but bit confused what will and won't fit the rcd300!
Any links and info much appreciated as always
Matt
Offline th3_f15t
  • -Receive: 183
Re: Rcd 310 aux lead possible?
« Reply #1 on: October 22, 2015, 07:47:58 am »
Sounds silly but have you done a Google image search and looked at the back to see if there's a jack port available?
Offline Pashka
« Reply #2 on: October 22, 2015, 08:54:52 am »
None OEM unit has jack for aux on the back, aux comes from the quadlock wiring. Some of RCD300 supports aux, some not, depend from the manufacturer. Only RNS310/315 has aux port on the front.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Flyingscotsman
  • -Given: 26
« Reply #3 on: October 22, 2015, 09:00:21 am »
I fitted one of these Connects2 kits to my RCD 300 - it gives you a 3.5mm jack plug that can connect to phone or MP3 player
http://www.amazon.co.uk/Connects2-CTVVGX004-Passat-Adaptor-Interface/dp/B005FMYGAS
It plugs in to back of RCD 300 where the plug for 6 CD changer would go (will only work if you don't have one of these already)
Offline dale.edwards
« Reply #4 on: October 23, 2015, 02:35:10 pm »
I've also fitted this aux kit from amazon this week. I've got the RCD500 but they are very similar, just check you have the CD changer port available on the back.
I installed the little grey box that comes with it behind the climate control panel and have run the lead coming out the bottom of the centre console. Only took around 45 mins to do.
Works and sounds really good.
Only other tip you'll need is to be aware that when u take the radio out you take a lot of the centre console apart, and when you unplug the little light that shows if the passenger airbag is off, this will cause an airbag fault to appear if the battery is connected, this will need to be reset after.
