Author Topic: anyone tried VI monitor ?  (Read 5642 times)
Offline poko
« on: December 31, 2009, 12:58:13 pm »
hi all,
since i own a mk2 leon i have no real good option to install gauges in the car.
now , i am really interested to know , in a nice looking way (not honda. ... 2000 gagues with pod columns on c pillar) what are my EGT's AIR/FUEL , boost and intake temps.
i have came along this product :
i have no clue if it can display all those parameters,
anyone has any experience ? any other recommendations ?
Re: anyone tried VI monitor ?
« Reply #1 on: December 31, 2009, 02:17:31 pm »
Apart from the Vi Monitor there are 2 others.
The Liquid golf is already available for the diesels, but not yet quite finished for the TFSI engines. It will (so I'm told) have more information and diagnostics available than other systems once it is fully OBD compatible.
http://racediagnostics.com/cms/index.php?page=liquidgolf-options
Then there is the Dashdaq. Very snazzy looking and you can make up your own custom skins. Not fully Vagcom compatible yet either, but a decent option.
http://www.dashdaq.net/
« Reply #2 on: December 31, 2009, 06:43:19 pm »
Have a look at the scangauge the guys on the mini forum love em
http://www.scangauge.com/products/
Offline poko
« Reply #3 on: December 31, 2009, 08:41:33 pm »
all 3 options are OBD data only.
so i do not get full EGT / BOOST / WIDEBAND info , which are the most important parameters i need.
i got a link (but lost it , will get it tommorow again) for a jap company who makes a digital gague , normal 56 or 60 mm (you can have several) which display full obdii data as well as connect to a wide range of their offered sensors.
you can have up to 4 lines per gague.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #4 on: December 31, 2009, 09:41:15 pm »
 :popcornsoda:
Over the top mod list ;o)
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #5 on: December 31, 2009, 11:19:54 pm »
 :popcornsoda:
Offline poko
« Reply #6 on: January 01, 2010, 08:47:17 am »
right ,
i was reffering to PLX Devices
much cheaper and better option than the others i think
you can buy a multigague :
http://www.plxdevices.com/multigauges.html
which is basically an LCD gague with up to 4 parameters.
or you can buy WIFI KIWI with iphone interface :
http://www.plxkiwi.com/kiwiwifi/hardware.html
those two display OBDII , but the great thing is that you can add modules to that for extra info :
http://www.plxdevices.com/sensormodules.html
looks really nice.
i can get just 1 gague and dash mount it with the entire info i need.
anyone tried those ?
« Last Edit: January 01, 2010, 08:50:29 am by poko »
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #7 on: January 01, 2010, 09:29:20 am »
^^^ The PLX stuff looks good but when I last checked a few months ago it had very very limited support for the Mk5 Golf / Mk2 Leon.
While it's OBD-II compliant so can get some very basic info most of the useful info isn't available via the older K-line protocol as our cars mainly use the CAN BUS protocol now.
Offline poko
« Reply #8 on: January 01, 2010, 10:02:32 am »
not good.
there are so many good options for the mk5 , but non for the leons.
frustrating.
« Reply #9 on: January 01, 2010, 11:19:49 am »
As I said earlier, the liquid one for the TFSi is still in development. I have been in contact with "freegeek" and he says that the can-bus should be cracked for use in the next month or so :happy2:
Also my understanding is that the Dashdaq II system is looking down this road too. :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #10 on: January 01, 2010, 11:23:12 am »
once they crack it for can bus what will you be able to moniter with it though?
« Reply #11 on: January 01, 2010, 11:38:30 am »
Here's Freegeek's PM to me in late November.
"We got the CAN version working for the first time last weekend, giving full access to all the vag-com blocks, poroduction will still take a couple more months though.
The difference between our system and others is that we use the proprietary VAG protocol which gives boost an other usefull info, while the others use the standard OBD2 protocol which does not show very much at all."
  • -Given: 243
  • -Receive: 155
« Reply #12 on: January 01, 2010, 11:52:21 am »
As soon as there's an option like these that shows boost on the TFSI i'm in  :xmaspresent:
Offline Janner_Sy
  • -Receive: 113
« Reply #13 on: January 01, 2010, 01:22:09 pm »
so would itbe able to do things like AFR as well, and if its can bus ready it potentially could read fault codes as well im guessing
« Reply #14 on: January 02, 2010, 01:18:22 am »
Yes and don't know (but like you hope yes!)
