Author Topic: Coolant hose  (Read 2655 times)
Offline Jay_ed30
Coolant hose
« on: December 29, 2015, 07:00:05 pm »
Evening all, doing usual checks on my car today and noticed my coolant level was lower than usual. So had a look around and noticed one of the hoses that runs behind the radiator fans on the passengers side has rubbed through and is leaking slightly. I'm going to try get the hose tomorrow from local dealer or tps just thought I'd try and see if anyone has the p/n in advance and if there is a solution to prevent te rubbing.
Circled is where the hose has rubbed ant the hose I need the p/n for
It comes from this t-piece at the top radiator hose passengers side also
Thanks and hope you all had a good Xmas
sent from my galaxy s6
Offline Jay_ed30
Re: Coolant hose
« Reply #1 on: December 29, 2015, 09:01:48 pm »
Anyone
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
05 | Tornado Red | DSG
Offline Jay_ed30
Offline Jay_ed30
Re: Coolant hose
« Reply #4 on: December 29, 2015, 11:29:12 pm »
Or 47 I'm not sure?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Coolant hose
« Reply #5 on: December 30, 2015, 12:12:55 am »
Just make sure the ED30 does not have different pipes.
Go here
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1731&ein=2008&f=625&hauptgr=1234567890
Select your year.
1. Engine, Clutch
Then find cooling system with your engine code.
Offline Jay_ed30
Re: Coolant hose
« Reply #6 on: December 30, 2015, 12:56:08 pm »
Go here
Select your year.
1. Engine, Clutch
Cheers for your help mate hose has been ordered from tps today. It's the hose that goes to the secondary water pump. Not sure how it's been catching the fan though
