Author Topic: Valve stem Seals on 2007 GTI  (Read 2766 times)
Offline Mego
« on: January 31, 2016, 07:36:02 pm »
Hi all,been having bluish smoke issue while going downhill when off gas,and when i push the gas a little a bluish puff of smoke came out and then disappear.
i did change the turbo and nothing changed..then i did a full pcv delete and same problem is still there..yesterday i did a compression test wet and dry and all is ok (153,150,150,148).
my question is could this be a bad valve stem seals?is it known that seals go bad in tfsi engines?
i think the only option now is the valve stem seals.
BR
Offline Bo!
Re: Valve stem Seals on 2007 GTI
« Reply #1 on: February 04, 2016, 03:50:01 pm »
Have you thought about having a leak down test .
Offline Mego
« Reply #2 on: February 05, 2016, 02:10:22 pm »
i did only compression test but seems its hard to do a leak down test in the city where i live bro..
