Author Topic: Gunk on oil filler cap  (Read 7293 times)
Offline Lewo
« on: February 01, 2016, 11:23:03 am »
hadn't topped the oil up for 2-3 wks and when I did on the weekend had a real shock when the inside of the cap was covered in loads of white gunk.
Panicked and thought oh no the head gasket was on the way out but dipstick is clean.
Is this a common thing with the GTIs this time of year? There was really quite a lot of the stuff so guess it means checking/cleaning more often...
Offline neiller
  • -Given: 32
Re: Gunk on oil filler cap
« Reply #1 on: February 01, 2016, 11:47:43 am »
Sometimes you can get a small amount when doing short runs . I think you get condensation in the engine and it mixes with the oil but don't think there should be that much! It could be an oil cooler fault , I had that problem on my a3 fsi a year ago it was relatively cheap enough to replace ! Head gaskets aren't prone to go on the tfsi engines as far as I know
Sent from my SM-N9005 using Tapatalk
B8ted
« Reply #2 on: February 01, 2016, 12:01:50 pm »
Lots of short journeys will cause this. As neiller said, it's condensation build up. I get the same as i only do a 3 mile round trip to work and back each day and the engine never gets warm. Giving it a good ol' Italian Tune up once or twice a week cures it.
Offline dronners
« Reply #3 on: February 01, 2016, 01:23:01 pm »
need pictures really to see how much you have but as said with short trips this time of year it can be expected
Offline Lewo
« Reply #4 on: February 01, 2016, 04:00:29 pm »
Cheers guys.
Yes mainly short run use, 6 miles to work.
I'll take some pics next time round but there was a lot of the stuff it had even dropped down off the cap.
Offline neiller
  • -Given: 32
« Reply #5 on: February 01, 2016, 04:17:42 pm »
Sounds like it may be too much check your coolant level / coolant for signs of oil in it
Offline bingbunny
« Reply #6 on: February 01, 2016, 09:41:32 pm »
I do about 4-6 thousand miles a month and I get it. Ive not had any engine heating issues. Or any issues at all for that matter.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: February 02, 2016, 07:47:45 am »
It's 100% normal for the time of year with the cold, damp air. Unless you have huge amounts of a thick 'mayo-like' substance under the cap, and all the way down the filler neck, I wouldn't worry.
Check your coolant is still nice and pink/red too, and not a horrid thick creamy like substance
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8 on: February 02, 2016, 07:19:33 pm »
Its been cover thousands of times - cold weather + short journeys = small amount of mayo on the filler cap. Take it for a long hard drive one a week to burn off the condensation.
Offline Lewo
« Reply #9 on: February 04, 2016, 12:05:35 am »
Pretty much spot on description that.
Coolant is fine though so will pay more attention in the winter when not having done any longer runs in the car.
Cheers all.
Patrick2691
« Reply #10 on: February 05, 2016, 11:17:27 am »
Any car I get I always use a marker and make a line on the coolant expansion tank so you can be sure your losing coolant whether it be a leak or head gasket etc. I get plenty of mayo on the filler as the car takes so long to warm up and I do 5 mile commutes
Sent from my LG-H955 using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: February 05, 2016, 05:09:14 pm »
It's when there is way too much on the dipstick is when you need to worry pal.
my tt did it a lot as I used her for short journeys and once a month to Birmingham which is when I gave her some beans  :signLOL: so I wouldn't worry too much about it but do keep an eye on things that's all. especially the oil as these stupid cars drink way too much oil than an Audi for sure.  :stupid:
