Author Topic: Fiscon Basic Plus with midline cluster and RCD510  (Read 1283 times)
Offline ReflexRob
« on: February 03, 2016, 08:49:09 pm »
Evening people.
I know nothing about this system but it looks impressive.
My GTi is an early 2005 car with AXX engine and 10 speaker audio.
I've updated the head unit to a Blaupunkt DAB (from 2010 Eos) and Canbus to a later one to stop battery drain.
My car has the Midline cluster only.
Can I still use the Fiscon Basic Plus system?
Offline ReflexRob
Re: Fiscon Basic Plus with midline cluster and RCD510
« Reply #1 on: February 03, 2016, 08:52:38 pm »
Just read that the Fiscon system doesn't show boost on TFSI engines.
Would a Polar FIS work instead with my setup?
Offline skard
  • -Receive: 245
« Reply #2 on: February 03, 2016, 09:02:36 pm »
The basic plus is visually controlled with highline and MFSW, and/or an OEM third generation stereo such as RNS510/RCD510.
It'd probably still work as a blind handsfree with your aftermarket stereo, that mutes your stereo during calls, but controlled through your phone entirely.
A polar FIS or other FIS+ devices can display boost, but you still need a highline cluster
Offline ReflexRob
« Reply #3 on: February 03, 2016, 09:04:41 pm »
Thanks.
Arse!
