Author Topic: Bleeding clutch master cylinder.  (Read 4536 times)
Offline GTI 500
« on: February 14, 2016, 08:04:23 am »
I have replaced the clutch master cylinder on my 58 plate golf gti, but cant seem to bleed it, is there a trickto bleeding it? Do you need to use vag tester? Any advise would be great.
Offline GTI-MATT
  • GTI-MATT
Re: Bleeding clutch master cylinder.
« Reply #1 on: February 14, 2016, 10:19:23 am »
Gravity bleeding usually works make sure the reservoir is always full undo the bleed nipple on the slave cylinder and let it run through. Tighting the nipple back up after a minute or 2 pump the peddle and see how it feels. If it dont feel right or peddle stays down pick back up with your hand and repeat procedure
