Author Topic: Window Motor Problem. What an absolute mess!!  (Read 21824 times)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Window Motor Problem. What an absolute mess!!
« Reply #15 on: February 15, 2016, 06:58:11 pm »
In march I will be down Midlands way, so if you're still stuck, let me know.
Good luck!
VCDS (Preston, Lancashire)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #16 on: February 15, 2016, 09:53:49 pm »
OMGOSH that terrible  :surprised:
I know I was so shocked! I can't think how it could get like that!
Water must be getting in there to have done something like that.  :sad1:
When repairing, heat the cables up with the iron and then touch the solder to it so it melts into the wiring. Sounds easier than done but doable as mentioned. I've done it on a vw alhambra and make sure you stick the heat shrink in between before you join the wires together.
Good luck  :happy2:
« Last Edit: February 15, 2016, 09:58:03 pm by r5gtt »
Offline Craigh1983
    • Leicester Wedding Photographers
« Reply #17 on: February 15, 2016, 09:58:33 pm »
I did notice earlier actually that the rubber flexible bit that lips onto the frame of the car was a bit lose so I might have to look into sealing this somehow when I have soldered the cables.
Offline doylebros
  • -Receive: 310
« Reply #18 on: February 15, 2016, 10:01:18 pm »
« Last Edit: February 15, 2016, 10:05:32 pm by doylebros »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #19 on: February 15, 2016, 10:12:47 pm »
That's probably it Craigh, not had a look at the fitting of the rubber but if you can get a small or thin cable tie around for a cheap fix then just do that if you're not got to replace the thing as I have seen the door removed and it's a pain of a job to align back up. Thought I'd just be an unplug and stretch the rubber over but don't think it is.
