June 20, 2026, 06:24:15 pm
All Things Mk5
Mk5 General Area
Diverter Valve issues with Full under-tray.
Topic: Diverter Valve issues with Full under-tray. (Read 8234 times)
GTiBlues
Always Involved
-Given: 7
-Receive: 15
Mr Blues
My Ride:
February 22, 2016, 07:09:52 pm »
Going from a Revised D to a G within 6 months. Then the G failing in less than 10 months.
Is HEAT the main reasons for them for failing?
As soon as I fitted my Full under-tray when I fitted my Revised D. I seem to be eating diverter valves.
My car is only running a Stage 1 Revo. So would it be worth fitting the short under-tray?
Build Thread -
http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
AJP
Global Moderator
Just look at my post count
-Given: 392
-Receive: 317
Re: Diverter Valve issues with Full under-tray.
Reply #1 on:
February 24, 2016, 05:36:35 pm »
Tough one to answer. Only thing I can contribute is that on k03 cars the dv is closer to the turbo and would in theory be subject to more heat than the dv on a k04 car.
So if you're k03, heat could indeed be playing a big part in the problem.
If the full undertray you're referring to is the special aero thing off the mk6 Bluemotion, then maybe there's a point that it wasn't designed for a car with components being subjected to mapped GTI temperatures..? But that does seem a bit of a stretch for an explanation!
skard
-Given: 5
-Receive: 245
My Ride:
Reply #2 on:
February 24, 2016, 05:45:24 pm »
I put a full sized undertray on my ED30,
No heating issues in general. Then again, my DV was up top.
Also, my current car has shields pretty much front to back, it is better for keeping crap out in my opinion.
Last Edit: February 24, 2016, 05:47:21 pm by skard
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #3 on:
February 24, 2016, 06:21:20 pm »
I've ordered today the full engine undertray.
Parts:
-1K0825237P
-1K0825951 (x3)
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
GTiBlues
Always Involved
-Given: 7
-Receive: 15
Mr Blues
My Ride:
Reply #4 on:
February 25, 2016, 09:42:03 pm »
I can't remember what model it was off from. It's got the golf ball effect on it. It's a genuine part and there are slots around etc.
It's a K03 turbo.
When my DV+ arrives I'll the stick the short tray on and zip tie up the oil level sensor cable.
Build Thread -
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #5 on:
February 25, 2016, 09:48:58 pm »
My K03 2+ with Meth kills them in 18-24 months
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
GTiBlues
Always Involved
-Given: 7
-Receive: 15
Mr Blues
My Ride:
Reply #6 on:
February 25, 2016, 09:50:49 pm »
I'm not even lasting 12 months.
Build Thread -
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #7 on:
February 25, 2016, 09:54:11 pm »
I ran a full undertray on my GTI and never had any issues. My G DV had no tears after a year when I replaced it when it went for mapping.
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
richtung
Won't Shut up.
-Given: 13
-Receive: 56
Reply #8 on:
February 25, 2016, 10:04:28 pm »
What are the benefits of running a full undertray?
How much for all the parts?
Rich
GTiBlues
Always Involved
-Given: 7
-Receive: 15
Mr Blues
My Ride:
Reply #9 on:
February 25, 2016, 10:05:53 pm »
It's started after its been remapped. I don't want to go down the route of fitting a Forge and it's regular servicing.
Build Thread -
david25
Always Involved
-Given: 19
-Receive: 7
Reply #10 on:
February 28, 2016, 03:10:38 pm »
Quote from: richtung on February 25, 2016, 10:04:28 pm
Rich
Its about £35-£40 for the parts, see above.
1. I've been running one for about 50,000 with no problems with the G valve.
2. Benefits, quieter on motorway, slightly better MPG, less water spray in engine
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #11 on:
February 29, 2016, 11:36:15 am »
I noticed no increase in MPG or noise reduction. It may reduce noise outside the car when idling.
The reason I got one was increased protection under the car from debris (being on air I was low and it would scuff before i hit the subframe).
Detailing Guide
Wheel Fitment Guide
GTiBlues
Always Involved
-Given: 7
-Receive: 15
Mr Blues
My Ride:
Reply #12 on:
February 29, 2016, 07:15:10 pm »
I gather then it could be something else causing it to fail.
Only thing I've noticed with the full tray is how light the steering feels at higher speeds.
Build Thread -
MS1
Always Involved
-Given: 5
-Receive: 3
Reply #13 on:
March 01, 2016, 06:31:34 pm »
I was just about to create a post regarding G revision diaphragm and Forge DV. I've had the latter on my car for 4 years and 70,000 miles and never had an issue. I've now booked into R-Tech in Leicestershire for a change of map for stage 2+/3 and they say they won't touch the car with a Forge DV on and I have to change the back to a revision G. I will do so as I want to see what their map offers over my custom Evolution Chips map, but I found it a little strange tbh.
R-Tech Map/ Longlife TBE w/200 cell Sports Cat / ITG Maxogen G60 / Loba HPFP / Forge Twin FMIC / Forge TB Hose / R8 Coilpacks / Neuspeed Power Pulley / EBC D&G Front & Rear Discs / EBC Yellowstuff Pads / BSH PCV Kit / Super-Pro Front & Rear / W.A.L.K / APR Torque Arm / 034Motorsport Density Line Engine Mounts / Vibratechnics Subframe Mount / Vibratechnics Dogbone Bush
284bhp / 307lbft
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #14 on:
March 01, 2016, 07:01:30 pm »
Forge DVs sound cool but can in some cases be problematic.
rtech want the absolute best hardware so using the oem g dv is the way forward.
Detailing Guide
Wheel Fitment Guide
All Things Mk5
Mk5 General Area
