Author Topic: Fans on after coolant flush  (Read 2181 times)
Patrick2691
« on: May 06, 2016, 08:08:02 am »
Drained the coolant to replace the online thermostat on my 06 DSG. I refilled as much as I could and then started the engine and the coolant level sensor pinged as it sucked all the coolant in, filled with the remaining coolant and the light went out all is well.
Only problem is both fans run constantly now while driving and for 10 minutes after shutting off. There is enough G13 coolant in the system and monitoring the coolant temp on polarFIS it's heating up normally etc.
I cleared a EML this morning which was p0118 002 - Engine coolant temperature circuit to high and it hasn't reappeared. Any ideas?
Sent from my LG-H955 using Tapatalk
Patrick2691
Re: Fans on after coolant flush
« Reply #1 on: May 06, 2016, 08:09:34 am »
Doh!! Forgot to plug the ECT back in! Just did it now and ran the car again but the fans are still running constantly with a 10 minute overrun??
« Last Edit: May 06, 2016, 08:34:33 am by Patrick2691 »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: May 06, 2016, 10:47:00 am »
Now you've plugged the sensor back in  :stupid:
Clear all codes again. hope that helps
Patrick2691
« Reply #3 on: May 06, 2016, 11:05:12 am »
Codes are cleared but it's still happening. I'm gonna chase the wiring from the sensor and see if it's all intake etc later
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: May 06, 2016, 11:23:01 am »
Other than that it could be the the temp sensors that have failed. we have two on the gti
« Last Edit: May 06, 2016, 11:27:40 am by r5gtt »
Patrick2691
« Reply #5 on: May 06, 2016, 11:34:02 am »
Yeah I know this one is prone to failure but it seems a bit coincidental it happened as I flushed the coolant etc. I need to look at the fan switch too I think
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: May 06, 2016, 11:38:11 am »
If you have a multi tester you may as well check the feeds have power coming to them too. taking the connector off the coolant sensor should make the fans run continuously and when plugged back in should stop them from running.
