Author Topic: CANBUS Gateway  (Read 2851 times)
Offline bbfb10
CANBUS Gateway
« on: June 16, 2016, 03:21:02 pm »
My Gateway is right up above where the clutch pedal would be, how the chuff do people get to it?  Ive been upside down with my head in the footwell and I still cant get my hands to it to plug in my Polar Fis. Any tips please?
Full VCDS Hex + Can.
Offline aadilp1
Re: CANBUS Gateway
« Reply #1 on: June 16, 2016, 03:34:02 pm »
take off the bottom cover and the footwell heater plastic pipe.. should be easily accessible then
Offline Stupots
  • -Given: 18
Re: CANBUS Gateway
« Reply #2 on: June 16, 2016, 03:39:06 pm »
What he said. 60 seconds, a few screws and it's way easier! Look at your PolarFIS connector to figure our how to release the one you cant see  :happy2:
Offline bbfb10
Re: CANBUS Gateway
« Reply #3 on: June 16, 2016, 03:50:00 pm »
Ive done all that. My question is how to get my hands into the tiny gap to reach the connector so l can unplug the CANBUS and put my Polar Fis in. I was lying down upside down on my drivers seat and still couldnt get my hands into the gap or see what l was reaching for.
Offline raz469
Re: CANBUS Gateway
« Reply #4 on: June 16, 2016, 04:26:04 pm »
When laying down on the carpet try getting at it with your left hand.
It can be painful to even Get your had infront of you at this point, but preserve. With all had to get it out.
The clips is on the top once its pushed in pull the connector. This should stop the clip going back to its seat. And then just keep wiggling and pulling.
Also see how tight the connectors are by fitting cable to the new can. You'll see how much of a push and pull they need.
Any more help lemy know
Offline raz469
Re: CANBUS Gateway
« Reply #5 on: June 16, 2016, 04:27:58 pm »
Also try moving your steering wheel up and out and getting a hand in under it. If it helps.
My arm got stuck once i unclipped. The plastics on this car really hurt.
Offline bbfb10
Re: CANBUS Gateway
« Reply #6 on: June 16, 2016, 04:33:21 pm »
Ive tried the steering wheel thing, my back is in pieces. Fingers crossed it goes better tomorrow.
Offline raz469
Re: CANBUS Gateway
« Reply #7 on: June 16, 2016, 04:36:30 pm »
Aw ye. I know what you mean. I feel f*cked today. Hopefully unrelated.
But that fking footwell is starting to get on my nerves.
Where abouts are you bbfb10?
Did you go for the beta update?
Offline bad devotions
  • -Given: 19
Re: CANBUS Gateway
« Reply #8 on: June 16, 2016, 04:39:45 pm »
From what I remember it was a royal pain in the arse taking the bugger out. Took me a while but it is possible.
Sent from my Nexus 5 using Tapatalk
Offline bbfb10
Re: CANBUS Gateway
« Reply #9 on: June 16, 2016, 04:49:38 pm »
Im near Burton on Trent in Staffordshire.
Offline 993BOY
  • -Given: 18
Re: CANBUS Gateway
« Reply #10 on: June 17, 2016, 08:49:01 am »
Had the same problem with mine, what a bl**dy awful job it was! don't fancy doing that again in the future, luckily my new Pirelli must have the later canbus, as it is fitted with the satnav unit already, phew!!
I remember it too me the best part of a day between everything, took a while to find it after firstly taking off wiper panel and hoping it was there!
Good luck anyway, sure you will get there in the end  :happy2:
