Author Topic: New Flywheel and Clutch, can't get into gear.  (Read 35604 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: New Flywheel and Clutch, can't get into gear.
« Reply #30 on: July 08, 2016, 01:27:03 pm »
Progress  :laugh:
Dont know how you managed to under tighten those bolts  :slap:
« Last Edit: July 08, 2016, 01:28:57 pm by r5gtt »
Offline ChazGTI
« Reply #31 on: July 08, 2016, 03:06:11 pm »
All Sorted! Can't believe it was that.
Can't look over the basics!
Not sure how I managed to under tighten them that badly, but then again I didn't have a torque wrench that fitted the 12 point socket so I had to improvise.
Lesson learned!
Thank you all for the fantastic help and suggestions  :happy2:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #32 on: July 08, 2016, 03:31:35 pm »
Great news. Hope they're tight enough now, big of thread lock is normally a good idea
Offline xjay1337
  • -Receive: 377
« Reply #33 on: July 08, 2016, 05:11:42 pm »
Well as @Dan_FR had pointed out, I had under-tightened the PP bolts. Just finished slowly tightening them through the starter hole while a friend rotate the crank.
Tested the clutch and now the PP stays still like it should. Gonna put everything back together and HOPEFULLY all will be good.
Result!!! :-)
Offline ChazGTI
« Reply #34 on: July 08, 2016, 06:02:21 pm »
Yep used some loctite blue!
Man, the difference in a new clutch and flywheel after the state mine were in is so bloody nice!
Offline TF51 AWD
  • Newbie
« Reply #35 on: October 27, 2025, 10:13:12 pm »
Did you get to the bottom of this issue ive got the same problem with my twin plate clutch
Offline mjmallia
  • -Receive: 60
« Reply #36 on: October 29, 2025, 08:03:53 am »
Answer is on the end of the second page.
Mike
South Coast
