Author Topic: Engine Management Light - Error code P0441  (Read 4435 times)
Offline Cadders96
« on: July 08, 2016, 09:42:50 am »
I have been getting the P0441 error code when I plugged in my friends EML scanner, I had cleared this twice but it seems to come back every 6 weeks. I have read that it is something to do with EVAP Incorrect flow but what I am wondering is what should I check to see is faulty or jammed etc.... If you could also explain what is meant but EVAP Incorrect flow that would be great.
VW Golf GTI Mk5 3 door
18" Monzas
Tinted Windows
Powervalve WRC Sports Cat-Back Exhaust with Decat Downpie 3" (Ebay Special)
Climair Wind Deflectors
HID Foglights
GFB DV+
Pre-Cat Delete
Offline GTI_Kyle
Re: Engine Management Light - Error code P0441
« Reply #1 on: July 08, 2016, 02:45:15 pm »
I had the exact same code come up mate, I replaced my N80 valve & it hasn't come up since  :happy2:
Stage 2 Graphite Blue DSG GTi - Too many mods to list...
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: July 08, 2016, 02:48:03 pm »
It could be a number of things. Failed N80 is one, a blockage in one of the pipes is another, or a charcoal canister that is in need of replacing as the activated charcoal inside is 'full' and is no longer able to store vapour.
The underlying cause is no flow of petrol tank vapours in to the inlet manifold via the N80 solenoid valve.
Offline Cadders96
« Reply #3 on: July 08, 2016, 02:58:48 pm »
Where is a good play to buy one?
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline GTI_Kyle
« Reply #4 on: July 08, 2016, 03:23:50 pm »
TPS or Sere motors bud
Offline Paulo P
« Reply #5 on: July 08, 2016, 03:58:12 pm »
I had the same error and as said it can be one of a few things. I started with the N80 valve and that cured mine and I bought mine from TPS.
Offline brinks787
« Reply #6 on: July 08, 2016, 05:18:58 pm »
I had the same error and had to replace the carbon cannister, well worth checking all the pipework to it is secure first though.
Offline simonshotter
« Reply #7 on: October 28, 2016, 05:24:47 pm »
Do you guys have the part numbers for TPS or Sere? Im considering taking my carbon canister off and  burning the carbon this weekend to see if that works. can you also buy new activated carbon use in fish tanks to add to the canister as replacement carbon?
Also, when you buy a new canister, is is fair to assume they come full of carbon as some of the images make it seem more like it is the outer shell only.
