Author Topic: Cold Air Intake Removal  (Read 3223 times)
Offline DubED30
« on: January 19, 2010, 01:19:43 pm »
I'm thinking of fitting a cold air intake, or similar before having my car Revo'd.
I want to easily be able to change back to the standard air box/filter.  Spannering isn't a problem, I just don't want to get one where things have to be cut and shut.
Any feed back from what you guys have fitted, would be very much appreciated.
Re: Cold Air Intake Removal
« Reply #1 on: January 19, 2010, 02:41:08 pm »
Are you thinking of wanting a high-flow pipe and cone filter type or a ram scoop using a flat panel filter in the stock airbox (like a Carbonio)?
Offline DubED30
« Reply #2 on: January 19, 2010, 04:35:26 pm »
Was looking at possibley a cat back exhaust, DV & stage 1 map.  Would a Carbonio work alright with that type of setup? or do you think go for the high-flow pipe?
Still wanted to keep it easy to put back to standard as under warranty.
« Reply #3 on: January 19, 2010, 11:03:46 pm »
I ran a Carbonio with ITG flat panel filter for about 50k miles with Revo1 and Revo2 plus Milltek TBE and forge DV without problems.
Easier to put back to standard with the Carbonio but a high-flow tubular intake will add more bhp.
My Carbonio is for sale if you're interested but you should decide what you want for your car in the longer term perhaps.
Offline DubED30
« Reply #4 on: January 20, 2010, 01:09:08 pm »
Thanks for the info, I'll mull it over :happy2:
Offline Damian @ DPM
  • DPM Performance
« Reply #5 on: February 03, 2010, 12:40:17 pm »
We're getting a lot of positive response on the new Pipercross Venom:
http://www.dpmperformance.co.uk/pipercross-venom-cold-air-intakebr-golf-5-gti-20t-fsi-golf-5-gti-edition-30-20t-fsi-1003-p-4908.html
Damian @ DPM Performance
Advertising removed... (for the time being)
Offline DubED30
« Reply #6 on: February 04, 2010, 09:41:56 pm »
Looks like that fits where the original air scoop is behind the grill.  Is that right??
  • DPM Performance
« Reply #7 on: February 08, 2010, 01:29:47 pm »
That's right yes.
  • DPM Performance
« Reply #8 on: February 08, 2010, 01:32:05 pm »
Here's some power graphs from the testing:
