Author Topic: K03 to k04  (Read 13478 times)
Offline Gisli
K03 to k04
« on: July 28, 2016, 04:01:53 pm »
Hi guys
My wastgate exuator rod is broken on my k03 turbine and I'm going to upgrade to k04. Just to be sure. The k04 is a straight fit on to my engine. I have 2006 gti. And what injectors do I need, if I have to swap them.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: K03 to k04
« Reply #1 on: July 28, 2016, 07:18:07 pm »
You need more than just the turbo. This is quite comprehensive:
You'll be better with injectors off a k04 car, so an 8P S3, mk6 R, etc. You could in theory use your k03 injectors, but you won't get full power potential, and any generic k04 conversion map will be for a car with k04 injectors.
You'll definitely need a remap, as soon after the conversion as possible. Running a k04 on a k03 map isn't a great idea.
I'd imagine most generic k04 conversion maps are classed as Stage 3, so they're designed with all the usual Stage 2+ hardware in mind as well as the turbo.
If you don't / won't have all those extra hardware upgrades, and you're essentially turning your car into a Stage 1 Edition 30, you'll want a custom map from the likes of R-Tech or Unicorn.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: K03 to k04
« Reply #2 on: July 29, 2016, 08:58:51 am »
Some early GTIs are not suitable for a straight turbo swap. AXXs for example need a lot more work, but I'm not sure what work that is. Make sure you know what you need before you dive in.
PLANS: Stage 2+
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: K03 to k04
« Reply #3 on: July 29, 2016, 09:53:26 am »
Really? I haven't heard that before. The AXX and BWA really aren't a million miles apart. Marginally higher compression on the AXX.
dansmith180
Re: K03 to k04
« Reply #4 on: July 29, 2016, 11:41:46 am »
They don't need any additional work. They're basically exactly the same bar a few little internal tweaks.
Offline Paradox1
  • -Given: 41
Re: K03 to k04
« Reply #5 on: July 29, 2016, 02:13:56 pm »
how much do k04's go for these days
Offline bbfb10
Re: K03 to k04
« Reply #6 on: July 29, 2016, 07:23:29 pm »
I picked up mine from a 70k ed30 for £250
Full VCDS Hex + Can.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: K03 to k04
« Reply #7 on: July 29, 2016, 08:31:51 pm »
I'm starting to wonder whether there'll still be any low mileage k04s around when I eventually get round to doing mine..
They're all IHI on the mk7 chassis now I think.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: K03 to k04
« Reply #8 on: July 29, 2016, 08:38:54 pm »
Or go K03 hybrid. Only need to change the turbo (not injectors etc) and you get a safe 360bhp on an awesome curve and better spool than even a K04  :drool:
Pretty sure Beach Buggy turbos do it for around £600-800
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: K03 to k04
« Reply #9 on: July 29, 2016, 08:43:28 pm »
Yeah, it's still as much of an option as a k04. Think the BBT hybrids are closer to a grand though? Either way, still an option.
If BBT pulled their finger out and got the new website up I could spend hours on it researching (drooling over) the shiny new turbos...!
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: K03 to k04
« Reply #10 on: July 29, 2016, 08:47:57 pm »
Here's a recent graph of a BBT k03 hybrid with R-Tech map for those interested. It's damn impressive.
Offline Gisli
Re: K03 to k04
« Reply #11 on: July 30, 2016, 03:32:36 pm »
What power figures should I get with k04 and map but on stock injectors?
Offline Paradox1
  • -Given: 41
Re: K03 to k04
« Reply #12 on: August 01, 2016, 10:28:27 am »
not much over the BBT hybrid id say.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: K03 to k04
« Reply #13 on: August 01, 2016, 01:00:10 pm »
Around 300bhp
Offline Gisli
Re: K03 to k04
« Reply #14 on: August 08, 2016, 05:47:59 pm »
Ok I picked up a original k04 from ed30 and I have BWA engine. If I'm understanding this right I should be able to bolt on the turbo without anything else. Right? I just have to change the diverter valve relocation wich are just some silicone hoses I think.
And I'm going to run on stock injectors to start with. But the car will be custum remapped straight after the swap.
