Author Topic: Wheel bearings  (Read 1435 times)
Offline Rick18ts
Wheel bearings
« on: August 18, 2016, 11:07:31 am »
Apparently there are 2 sizes of wheel bearings for my 55 plate. How do I know which one I need?
Offline irish_ram
  • -Given: 200
Re: Wheel bearings
« Reply #1 on: August 18, 2016, 11:22:34 am »
I think the only way is to remove and measure as there was no standard size fitted for specific models etc
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Wheel bearings
« Reply #2 on: August 18, 2016, 09:27:25 pm »
Is this for front wheel bearings?
I did mine recently, they come in a bolt on housing.
There are two types:
One has 3 mounting bolts
Later type has 4 mounting bolts
Jack car up and loom at back of hub where driveshaft goes into the hub.
You will see the 3 or 4 bolts,
Then you know which one to order :)
Hope this helps.
Jas
VCDS (Preston, Lancashire)
Offline Pesky jones
Re: Wheel bearings
« Reply #3 on: August 18, 2016, 11:34:49 pm »
Hi mate.
If you are talking about the internal diameter -  I had to swap a bearing a while ago, and got the wrong size the first time. Unfortunately I cant remember whether it was the 30 or the 32mm that was right. I got told that even with vin numbers etc, you cant know which yours has. However, afterwards I searched posts and it seemed that a few people with a GTI was one size. It made me think that the diameter varies between the mkv platform (R32, GTD etc.)opposed to varrying between GTIs. But then again I only saw a handfull of examples. Ill search my posts to try and.find the right size
« Last Edit: August 18, 2016, 11:38:26 pm by Peskyjones »
