Author Topic: Loba hpfp and fuel return valve  (Read 1222 times)
Offline martinEd30
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,106463.0.html
« on: August 18, 2016, 06:57:39 pm »
Ok, so took the plunge and ordered a loba hpfp and an rs4 fuel return valve for the ed30 :) so does anybody have an advice on fitting the return valve as i can find guides on how to fit the fuel pump but not the valve? And does any one have an hints or tips for fitting both? And things to look out for?
Cheers guys
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Loba hpfp and fuel return valve
« Reply #1 on: August 18, 2016, 07:00:10 pm »
Yeah when you get both parts fit thr RS4 valve one by removing the old one and fitting the new one.
Offline KieranM
« Reply #2 on: August 18, 2016, 09:24:16 pm »
The RS4 valve is a complete pig to fit! If you're planning on doing RFD and valve cleaning then I'd suggest doing RS4 valve then as it makes life a lot easier when the inlet manifold is off.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: August 18, 2016, 10:27:29 pm »
oh crappers I thought it was fitted to the hpfp  :thinking:
