Author Topic: Connecting an Amp to RNS 510  (Read 8079 times)
Offline loop
  • -Given: 26
« on: September 10, 2016, 11:01:46 pm »
I have bought a Pioneer GM-D1004 amplifier which I intend to connect to my RNS 510 in the hope it will at least slightly improve sound quality (using the stock 10 speakers for now).  Am I right in thinking I need one of these:
http://www.ebay.co.uk/itm/160511768862?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
If not that, what is the adaptor I need to hook it up?  Are there any coding changes that would be needed, I read something about changing to VW sound system in VCDS?
Cheers all!
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline loop
  • -Given: 26
Re: Connecting an Amp to RNS 510
« Reply #1 on: September 12, 2016, 04:31:47 pm »
Can anyone help with this? Just need to know if I need an adapter to connect amp to RNS 510.
« Reply #2 on: September 12, 2016, 05:19:58 pm »
Yeah you need a adapter to split the single
Offline Pashka
« Reply #3 on: September 12, 2016, 09:27:15 pm »
You need to solder the plugs, because I haven't seen any adapter for rns510. That one will not fit, or you can buy it, cut on the soldering points and solder to your loom. Yes, you need to change the coding for sound system to get the proper signal for the amp or brake/take the pins out from the black plug and put to your quadlock.
« Last Edit: September 12, 2016, 09:32:04 pm by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline loop
  • -Given: 26
« Reply #4 on: September 13, 2016, 12:53:02 am »
Ok thanks for that. They don't make it easy do they? I guess they never intended the RNS 510 to be used with an aftermarket amp!
Offline SI-R32
  • -Receive: 126
Offline loop
  • -Given: 26
« Reply #6 on: September 14, 2016, 06:17:20 am »
http://www.r32oc.com/topic/45797-rns-510-pre-outs/
Cheers for that, but it's a bit over my head tbh. Will have to find an audio specialist I think as EddieNL doesn't fancy installing it!
Having read the instructions, there is the option of connecting the units using the RCA input jack of the amplifier to the stereo RCA output jack, or by connecting the stereo speaker output wires to the amp using the supplied speaker input cord.
Offline biffobear
« Reply #7 on: October 03, 2018, 05:24:43 pm »
Did you ever work out how to fit this pioneer amp, I just bought one and can’t work out if I need additional wiring for it.
Offline loop
  • -Given: 26
« Reply #8 on: October 03, 2018, 09:39:12 pm »
I think you can using the high level inputs, but I ended up fitting a blaupunkt amp instead that’s plug and play.
willni
« Reply #9 on: October 05, 2018, 12:04:54 pm »
You need high to low level inputs and then you just cut the speaker wires add it in and then connect it to the amp.
Offline biffobear
« Reply #10 on: October 05, 2018, 12:19:12 pm »
To enable fitting without cutting into the loom you need a quad lock with mini iso’s from dynamic sounds.
