Author Topic: Brake sensor  (Read 3173 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Brake sensor
« on: January 21, 2010, 06:02:15 pm »
Hopefully a quick and easy question...where is the brake sensor located (assuming there is one)?
Is it in the pads, or is there a separate bit?
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Brake sensor
« Reply #1 on: January 21, 2010, 06:30:32 pm »
Its built into the pad.  IIRC its only on one side of the front ...
Sepang Blue S4 BE Avant
Offline davv
Re: Brake sensor
« Reply #2 on: January 21, 2010, 06:31:20 pm »
it is in the pad, on the left, if i don't forget something :smiley:
Offline QD MBE
  • -Receive: 102
Re: Brake sensor
« Reply #3 on: January 21, 2010, 06:35:14 pm »
as above, located on the passenger side front brake.  Built into one of the pads.
  • MUBster DUBster
Re: Brake sensor
« Reply #4 on: January 21, 2010, 07:23:49 pm »
I guess you lose the sensor functionality with after market brake kits then?
Unless, you can get Ferodo DS2500 pads with them in?
  • -Receive: 453
Re: Brake sensor
« Reply #5 on: January 21, 2010, 07:32:48 pm »
TBH the sensor is pretty much pointless if you keep on top of maintainance as you would inspect all four corners of the car for pad thickness.
Offline QD MBE
  • -Receive: 102
Re: Brake sensor
« Reply #6 on: January 21, 2010, 07:37:41 pm »
you could always buy something like a porsche sensor, and splice it into the VW wiring, and drill a hole into the pads.  if you drill close to the pad backing plate, and glue the sensor in all should be well.
Re: Brake sensor
« Reply #7 on: January 21, 2010, 07:57:15 pm »
....Regular visual inspection is my preferred method too.
I currently run Ferodo DS2500 pads but wasn't aware of any sensors in/on them.
  • MUBster DUBster
Re: Brake sensor
« Reply #8 on: January 21, 2010, 08:14:41 pm »
I think I'll stick with the visual inspection...  :drinking:
