Author Topic: Coolant temp sensor  (Read 3390 times)
Offline s3dubbin
Coolant temp sensor
« on: September 22, 2016, 01:42:25 pm »
Looking to change the coolant temp sensor on my s3 8p thinking the part number is 06A 919 501A. Struggling to find it on the ECP page I phone them with that number and they come back with a radiator fan switch?? Their part number being 223440210? Is this the correct part but different name? Or not what im after.
Cheers, Stevie.
Offline s3dubbin
Re: Coolant temp sensor
« Reply #1 on: September 22, 2016, 01:43:07 pm »
  • -Receive: 691
« Reply #2 on: September 22, 2016, 03:28:31 pm »
06A 919 501A is definitely the right one for the engine ECU & dash gauge.
I replaced that (and the thermostat) at the same time on my Ed30 recently, which I believe has the same engine as the S3.   Not a pleasant job if the S3's sensor is in the same position!
Offline RMK87
« Reply #3 on: September 22, 2016, 08:12:55 pm »
Also looking to replace mine on the eddy. Is it just the one sensor? Or two?
Offline s3dubbin
« Reply #4 on: September 22, 2016, 08:42:42 pm »
Cheers for the reply. I went in and thankfully they found me the right one. Changed it over tonight but it hasn't stopped my rev hunting issue. Might try the fuel pressure sensor next.
Stevie.  :drinking:
Offline Lewo
« Reply #5 on: September 22, 2016, 08:44:08 pm »
Your not on about the sensor prongs in the expansion tank are you?
I replaced mine as kept getting the warning up on the dash when the weather turned cooler.
EDIT igore this then lol  :smiley:
  • -Receive: 691
« Reply #6 on: September 23, 2016, 10:22:26 am »
One I think.  I had the classic over cooling issue, so I replaced both.  The sensor sits in the thermostat housing, so would be fool hardy not to do both whilst you're there.  The sensor is about 40 quid from VW tho, ouch!
Offline RMK87
« Reply #7 on: September 23, 2016, 03:06:19 pm »
Yes it is just rang local VW. Ordered a thermostat (he said it comes as one unit with the housing and sensor?) and engine coolant sensor. £80 for both. Going to replace same time as timing belt and water pump. Is there anything else am missing?
  • -Receive: 691
« Reply #8 on: September 23, 2016, 03:16:45 pm »
Mine didn't come with a sensor!  Did it this summer.
The part looks like this and if yours comes with a sensor, that's good!
That's about it for the coolant circuit.
