Author Topic: Engine Light Flashing and Coil Pack Advice  (Read 4381 times)
Offline jaylufc17
  • -Given: 48
« on: October 08, 2016, 01:42:40 pm »
Have a GTI 57 plate DSG...
Was giving it a bit of a thrashing this morning and engine management starting flashing (presumed because i have no fuel)
just now it came back on again will full tank of fuel after heavy acceleration....
Is this the coil packs and spark plugs that are gone? if so which ones are recommended heard the r8 ones are the ones to go for, seen these on ebay
http://www.ebay.co.uk/itm/331858811102?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
going to the GTI Festivsal tomorrow at santapod and was hoping to give it a go at 1/4 mile lol....
Offline xjay1337
  • -Receive: 377
Re: Engine Light Flashing and Coil Pack Advice
« Reply #1 on: October 08, 2016, 02:21:02 pm »
When I had flashing EML it was coilpacks but also accompanied with a horrid misfire. Went away with Ignition cycle, didn't happen again, and were replaced under warranty.
I'd just replace all the coils and spark plugs anyway, cheap and easy to do.
I'm at VW Festival tomorrow, maybe see you on the strip :)
Offline jaylufc17
  • -Given: 48
« Reply #2 on: October 08, 2016, 03:21:28 pm »
cheers mate...
yeah hopefully lol just hope this holds up for the day
Offline EdiStage3
« Reply #3 on: October 12, 2016, 01:31:11 am »
Coil pack & spark plugs as mentioned above id change both, in my opinion the R8 coil packs made no difference performance wise over standard.
Offline irish_ram
  • -Given: 200
« Reply #4 on: October 12, 2016, 12:17:26 pm »
I believe the R8 coils are just for show and don't provide any performance benefits.
If you can get the car scanned rather than blindy swapping bits as may not be the cools or plugs.
Also when my coils went I rang vw as there was a recall on certain ones and mine were those ones so got all 4 replaced for free
Offline ducman77
  • -Given: 59
« Reply #5 on: October 12, 2016, 01:29:32 pm »
As said above, if you get a chance to hook up to a VCDS at the Festival you will get a definite answer as to which Coil pack is gone (if it is a coil pack?)
Replacing with the red coil packs, as others have said,  seems to be pretty much just for show as far as I can see :smiley:
I replaced my standard coils with the red ones and I have noticed no difference in performance improvement.
Just as a side note; if you are a stickler for part numbers, and original parts, it is worth noting that the red coils from awesome are "oem equivalent" and do not have Volkswagen/Audi part numbers stamped on them!
AKS tuning sell the coil packs with the original part numbers on them.
I ordered mine from Awesome before I realised they are "OEM equivalent" as opposed to full OEM.
I spoke to Awesome about it and they assured me that they are the identical coils from the same production line etc, etc. However, if I was doing it again I would order them from AKS :happy2:
HTH
Dave
Offline jaylufc17
  • -Given: 48
« Reply #6 on: October 12, 2016, 09:24:16 pm »
thanks guys!
all fitted no issues except having to go halfords in between as i was told 14mm would fit but it didnt (10mm fits)
had quick look at top of coil had numbers on there... couldnt see too well as i did it after work so was getting dark!
Offline irish_ram
  • -Given: 200
« Reply #7 on: October 12, 2016, 10:53:35 pm »
thanks guys!
Glad you got sorted but maybe worth getting the part number and ringing VW and if on recall then swap them back in and get replaced. then you could sell one set or keep as a spare
Offline jaylufc17
  • -Given: 48
« Reply #8 on: October 13, 2016, 06:29:02 am »
Ok will do I pretty sure I read somewhere about it being older than the model I have 57 plate... however will check thanks for the help
