Author Topic: Tiguan/cayanne calipers... brackets needed?  (Read 2402 times)
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« on: November 10, 2016, 11:12:16 pm »
Just had my new calipers turn up and they look really big but they only came with the bolts like in this link:
http://jhmotorsports.com/shop/catalog/front-caliper-bolt-kit-porsche-cayenne-brembo-piston-p-467.html?osCsid=1ede1644950e51d3963aa8ba08956a91
Anyone else run this setup and can confirm that's all I need to mount? I have spigot rings too and lines just confused to why no brackets are needed.
Pic from Internet for reference
« Last Edit: November 10, 2016, 11:18:14 pm by slix »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Tiguan/cayanne calipers... brackets needed?
« Reply #1 on: November 10, 2016, 11:49:48 pm »
No brackets although I prefer the fitting kit from epytec.de. I had the bolts and changed to Epytec's kit as you can see in my project. :wink:
Offline slix
  • -Receive: 38
« Reply #2 on: November 11, 2016, 08:35:19 am »
How come? I'll have a read cheers.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #3 on: November 11, 2016, 09:10:15 am »
It's a more solid kit. Just check the build thread, I think the pictures are self-explaining. :smiley:
Offline slix
  • -Receive: 38
« Reply #4 on: November 11, 2016, 09:13:10 am »
In the derv build or ed30? As the ed30 has about 30 pages lol. When did you roughly fit them as will help me Barrow it down.
Offline Paradox1
  • -Given: 41
« Reply #5 on: November 11, 2016, 10:17:09 am »
I got these. there huge!!!
Im guess these are the 4 pots??
They dont need brackets like th porsche/TTRS calipers
You need mounting bolts for them. i got a link somwhere for them. i'll post them later
Offline slix
  • -Receive: 38
« Reply #6 on: November 11, 2016, 10:47:14 am »
Nah I got the bolts which look like a 1mm tube on them, maybe to cater for the larger hole on one end.
 And yes they are 4pots. Not too heavy either too so maybe aluminium?
Just coming from smaller 4 pot porsche brembos with brackets I was just checking if I had all needed for the swap when I do it in a week or so.
Offline slix
  • -Receive: 38
« Reply #7 on: November 11, 2016, 10:48:53 am »
I know you don't get as good pedal feel as oem, but how do you find them?
My current 4 pots use a 312mm disc and wanted slightly bigger.
Offline Paradox1
  • -Given: 41
« Reply #8 on: November 11, 2016, 12:30:30 pm »
havent fitted them yet, I've been lazy.
I hear the pedal feel isnt a problem if they brake system(incuding ABS) is bled correctly.
Was contemplating getting the nqsbbk but then thought i may as well go bigger incase they wasnt sufficient enough.
330mm should be better but cant really tell until I get them fitted.
What pads are you going with? They cost a bomb :)
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #9 on: November 11, 2016, 12:42:40 pm »
The derv has R32 front brakes. It's here: http://www.mk5golfgti.co.uk/forum/index.php/topic,95592.msg1054687.html#msg1054687
The bolts and nuts work but I preferred to get something that's more solid. Also, those calipers are aluminium, so they're light. Just the bigger brake discs are heavier. :happy2:
Offline slix
  • -Receive: 38
« Reply #10 on: November 11, 2016, 02:25:30 pm »
Just the pads that came with the kit. Not had a look at brand yet. The discs are zimmerman
