Author Topic: Coding help - Hinckley  (Read 7295 times)
Re: Coding help - Hinckley
« Reply #15 on: December 11, 2016, 07:51:48 pm »
Not sure it's really R-Tech's domain.
Agreed really.
Offline white91
« Reply #16 on: December 11, 2016, 08:40:39 pm »
I'm booked in with them in January actually, however I need the correct loom then a bit of coding but I doubt rtech would be interested
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #17 on: December 11, 2016, 08:54:24 pm »
No worries, was just a thought as I guessed they'd have everything you needed once you got the loom, hope you sort it :happy2:
On this subject, if I wanted a mfsw do I have to buy one or just the buttons because mines dsg?
Offline white91
« Reply #18 on: December 11, 2016, 09:39:09 pm »
For a dsg wheel it's just the buttons I think, mine is manual so a bit more tricky
Offline mikezs
« Reply #19 on: December 11, 2016, 09:59:57 pm »
I've done this recently, so I can help, maybe.
That mk6 loom is compatible with the connections, but is not long enough to plug in properly. You might have pulled out one of the connections when you plugged it in. The horn probably doesn't work because you've got a cable jammed in the way.
What Steering wheel module did you replace with? CH version?
You really do need the correct mk5 airbag loom for this, so you should definitely get one before giving it in to be fixed
Offline white91
« Reply #20 on: December 12, 2016, 07:46:28 am »
I did notice the spade connectors were not long enough so I fitted them the only way it would go, so ideally I would extend the wiring?
Yeah I fitted a CH controller.
Does anybody know what the coding is for it?
Offline mikezs
« Reply #21 on: December 12, 2016, 09:41:11 am »
The coding depends on what other bits you've got on the car, but it's straight forward with VCDS. You need to set it to LIN 1.3, not 2.0
I wouldn't be trying to extend a loom on anything with the airbag connected to it. You can plug your old loom in for now without any problem.
The steering wheel/ESP/ABS lights won't go out until it's coded, but you just need to repeat the full left, center, full right until it's aligned. The power steering will just instantly start working. Took me 2 goes and 10 minutes of sh*tting myself before it just started working fine.
Offline white91
« Reply #22 on: December 12, 2016, 09:44:09 am »
Thanks, I think I might refit the original loom to get power steering back, will the other lights not go out if I do this?
Been quoted £54 for a loom from TPS, it's it's the usual go into branch, pay for it then collect few days later, I live miles away!
Other option is one from china?
Offline mikezs
« Reply #23 on: December 12, 2016, 10:25:49 am »
I got mine from China, It was Genuine VW, just with asian writing all over it. link: http://www.ebay.co.uk/itm/151532836896
The lights won't go out until you've coded the CH module and done the steering angle reset. The loom won't help you with this, it'll just enable the buttons and the horn to work properly.
« Last Edit: December 12, 2016, 10:28:51 am by mikezs »
Offline white91
« Reply #24 on: December 12, 2016, 11:12:04 am »
Thanks Mike, can all the coding be done now, and I simply fit the new loom when it arrives?
This is my daily vehicle and I should have done my research a little better!
Offline mikezs
« Reply #25 on: December 12, 2016, 11:13:37 am »
The coding can be done without fitting anything else, I installed my CH module and coded it before I did any MFSW installation
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #26 on: December 12, 2016, 11:54:59 am »
you need to look at the helper popup window and see what equipment you have on that list like cruise control, rear wiper, auto/manual etc and then work out what number goes where into the coding box
Offline white91
« Reply #27 on: December 12, 2016, 11:59:44 am »
Ok I'm gonna fit the old loom, code the CH controller with cruise, rear wiper, manual.
Order the correct loom and fit when it arrives.
Offline white91
« Reply #28 on: December 15, 2016, 10:38:02 pm »
One of my friends locally has VCDS, tried coding it tonight, it would accept any coding. I swapped the loom back to the old one to eliminate that, still no joy.
If I replace the swcm with the original should that work?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #29 on: December 16, 2016, 06:49:24 am »
Keep the CH one, its just the loom you need the correct one.
Sent from my SM-G928F using Tapatalk
