Author Topic: Which Thermostat  (Read 2860 times)
Offline Gary
Which Thermostat
« on: December 20, 2016, 07:23:50 pm »
Folks, I've had a look but I'm still. Ot sure which thermostat I require.
The symptoms:
Car even after driving for upto 2 hours will show a steady 75degrees odd on the display, it will only ever display 90 when I am slow moving stop, start traffic.
I know it needs replaced but is this the main thermostat or the inline thermostat?
It's a 2007 Edition 30 with a manual gearbox, any help is much appreciated.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Which Thermostat
« Reply #1 on: December 21, 2016, 01:09:19 am »
Main stat under the alternator  :happy2:
Offline Gary
« Reply #2 on: December 22, 2016, 11:01:00 am »
Thanking you, I have zero mechanical sense so off to the garage it goes.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: December 22, 2016, 11:14:22 am »
We can't know everything and can only learn  :happy2:
  • -Receive: 692
« Reply #4 on: December 22, 2016, 11:17:31 am »
The symptoms:
Mine is a manual 2007 Ed30 as well and there is only 1 thermostat on this car / model year.
Offline Gary
« Reply #5 on: February 04, 2017, 12:44:26 pm »
So a new Thermostat didn't fix the issue, did a bit more digging and found that the coolant sensor may be at fault, anyone else tried this?
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #6 on: February 04, 2017, 04:55:21 pm »
I'm pretty sure a coolant sensor will throw up a code.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: February 04, 2017, 11:10:06 pm »
No these stupid vag cars don't always throw up a code for the temp sensor  :doh:
Does the heat blast out like burning your hand type of heat?. Mine does now but that's because I've messed with the stat.
Offline Gary
« Reply #8 on: February 04, 2017, 11:42:15 pm »
It certainly seems to heat up quicker anyway which is nice at this time of the year.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: February 05, 2017, 01:04:03 am »
Only other things are the sensors then once situated near the stat and there's another on the gearbox side
