Author Topic: Removing letters  (Read 2447 times)
Offline Bozz
  • -Given: 60
  • My Ride: Golf GT TDI 57reg
Removing letters
« on: January 24, 2017, 07:00:58 pm »
Hi all, I'm thinking of taking the 2.0 TDI letters off the tailgate but I just wondered if it'll leave marks ? Thanks
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: Removing letters
« Reply #1 on: January 24, 2017, 07:03:24 pm »
No marks just residue.
Use fishing wire or credit card to remove then use wd40 or similar to get the rest of the sticky stuff off. Then follow up with a bit of Polish if needed.
« Reply #2 on: January 24, 2017, 07:46:49 pm »
I used a credit card and tar and glue to get the residue.My old gttdi
« Last Edit: January 24, 2017, 07:48:37 pm by Andy »
Offline Bozz
  • -Given: 60
« Reply #3 on: January 24, 2017, 07:49:38 pm »
Thanks both :)
Offline dronners
« Reply #4 on: January 24, 2017, 08:46:39 pm »
if you heat the letters up with a hairdryer or what i did was pour hot water over them it softens the glue so more comes off with the badge and you'll have less work cleaning up whats left
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #5 on: January 24, 2017, 08:58:44 pm »
Dental floss. Cuts through the adhesive nicely.
Then the usual tar/residue remover.
On some cars a light cut then polish was needed as a final stage as the paint under the badge hadn't been subject to the same weathering and/or washing and polishing as the rest of the car, so you'd end up with a kind of 'stencil' of the badge.
Done.
Offline shoaybmakda
  • -Receive: 54
« Reply #6 on: January 24, 2017, 10:21:57 pm »
Thanks for this - been meaning to replace my rear badges with the new MK7 red badges I've got. These tips will come in handy!
Offline spesh
« Reply #7 on: January 29, 2017, 11:24:02 am »
WD40 works fine for removing the residue, bit cheaper than the tar remover too ;)
Offline LNeoPT
« Reply #8 on: January 30, 2017, 01:21:43 pm »
I removed mine and i got them "marked" at the paint. Already tried to polish it but i can't remove the burn.
