Author Topic: Break booster pipe  (Read 2786 times)
Offline bradh
Break booster pipe
« on: January 28, 2017, 12:43:08 pm »
Spotted this pipe think its the break booster valve pipe its been wrapped in black tape
What effects wiuld this have on my car as having a slight hesitation on boost every now and then
Also does anyone know the part number for it so i can ring up my local vw and get one ordered
Sent from my SM-G920F using Tapatalk
Offline SamMas
Re: Break booster pipe
« Reply #1 on: January 28, 2017, 05:43:23 pm »
Unsure wether it will have any adverse affects, however if you check the part the part number will be on there buddy!
Offline barelyrelevant
« Reply #2 on: January 28, 2017, 10:28:11 pm »
They are known to crack on the fittings so that could explain the tape.
Shouldn't make a difference on boost unless your check valve is buggered in which case it could be letting boost past.
Could effect your vacuum on idle and brake feel though, the brake assist wouldn't be as strong so you'd have to push the pedal harder.
part number is 1K0 612 041 GM for the whole lot and plus you need  056 129 777 which is a little cap to cover the unused nipple on the newest revision of the brake booster kit.
^^ I only know that because i've jut had to order it for mine.
Offline bradh
« Reply #3 on: January 28, 2017, 11:04:50 pm »
Awesome chaps thanks will be ringing dealers Monday
Offline bradh
« Reply #4 on: January 28, 2017, 11:08:28 pm »
Can I ask how much you paid please
« Reply #5 on: January 29, 2017, 10:24:08 am »
£28 I think.
Offline bradh
« Reply #6 on: February 02, 2017, 08:29:40 pm »
£28 I think.
Cheers buddy order the parts should pick them up tomora all in for valve and blank pipe £34
