Author Topic: Brakes kit...any good?  (Read 4164 times)
Offline Bigjimknickers
  • -Given: 55
« on: February 02, 2017, 02:55:45 pm »
 :thinking:
Any good?
https://www.ebay.co.uk/itm/252616908251
Please no flaming a genuine question ''tis all! Need front & rear & pads so this popped up, I was about to pay more than this for just rear brembos (all on an OE stock MK5 Gti)
Ta
  • -Receive: 692
Re: Brakes kit...any good?
« Reply #1 on: February 02, 2017, 03:46:33 pm »
I think you know the answer already.
« Reply #2 on: February 02, 2017, 04:49:04 pm »
Probably wank. Why buy cheap brakes?
Offline Paradox1
  • -Given: 41
« Reply #3 on: February 02, 2017, 05:06:17 pm »
They work fine. upgrade them over OEM and didnt have no complaints
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: February 02, 2017, 05:11:31 pm »
I would go oem discs with mintex m1144 pads
Sent from my SM-G928F using Tapatalk
Offline horsemeat
« Reply #6 on: February 02, 2017, 11:08:43 pm »
Pretty blunt but I agree. Not a part of the car where you'd want to cut costs surely. Same with tires tbh.
  • -Receive: 692
« Reply #7 on: February 03, 2017, 09:51:11 am »
And a 150mph+ car at that.
I get money is tight for some people in these difficult times, but at the very minimum, fit discs and pads from VW.   I really wouldn't trust these chinese fakes on my car at Autobahn speeds.  Not only that, drillings and grooves serve no purpose what so ever on standard brakes, other than weakening them.
  • -Given: 55
« Reply #8 on: February 03, 2017, 02:08:29 pm »
Yea I think for the extra I'll go with the full brembo set:
https://www.ebay.co.uk/itm/252076638397
  • -Receive: 692
« Reply #9 on: February 03, 2017, 02:09:46 pm »
That is much better choice, providing it's genuine Brembo stuff and not Chinese knock offs  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: February 03, 2017, 03:32:57 pm »
I'd also recommend oem as opposed to cheap chit lol had a full set of grooved and drilled discs with red stuff pads on my tt and they were rubbish so went BBK route on front and they made a huge difference in braking.
Also think about replacing your brake hoses as these are a weak point and cause brake pedal travel!!!
Just my 2p worth:happy2:
  • -Given: 55
« Reply #11 on: February 04, 2017, 10:22:51 pm »
These look nice:
Are they genuine Ate though?
https://www.ebay.co.uk/itm/381351031964
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: February 04, 2017, 11:15:24 pm »
That's what it says but only suitable for ate system  :thinking:
2x GENUINE ATE Power Disc (24.0325-0158.1) brake disc front axle VENTED
1x Set (4 pieces) GENUINE ATE Ceramic brake pads (13.0470-7184.2) front axle
1x anti-squeal paste (do not apply on friction surface of brake pad or brake disc!)
RESTRICTIONS
Only suitable for brake system ATE!
TECHNICAL INFORMATION
Brake pads
Width [mm]: 155,1/156,3
Thickness [mm]: 20,6
Height [mm]: 66/71,3
Incl. wear warning contact
Length [mm]: 135
Brake system: ATE
Brake discs
Type: VENTED
Diameter [mm]: 312
Thickness [mm]: 25,0
Height [mm]: 49,9
Number of holes: 5
Pitch circle-Ø [mm]: 112
With screws
MAPP-Code available
Surface: Coated
Processing: High-carbon
  • -Given: 55
« Reply #13 on: February 05, 2017, 08:35:46 am »
RESTRICTIONS
Brake pads
Length [mm]: 135
Brake system: ATE
Brake discs
Type: VENTED
Diameter [mm]: 312
Height [mm]: 49,9
Number of holes: 5
With screws
MAPP-Code available
Surface: Coated
Ok, sorry for the noob question but how do I find out what OE system I have then? Mines a 2006 mk 5 gti totally stock.
Offline Lewo
« Reply #14 on: February 05, 2017, 09:59:43 am »
Someone will know better than me on here, but I was told by my mechanic mate to look at the master cylinder to see what marking it has on it.
Mines a 56 plate and it's ATE I think.
Take a pic or two with your phone as it's hard to get at.
