Author Topic: Brakes kit...any good?  (Read 4055 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Brakes kit...any good?
« Reply #15 on: February 06, 2017, 02:58:33 am »
That's what it says but only suitable for ate system  :thinking:
2x GENUINE ATE Power Disc (24.0325-0158.1) brake disc front axle VENTED
1x Set (4 pieces) GENUINE ATE Ceramic brake pads (13.0470-7184.2) front axle
1x anti-squeal paste (do not apply on friction surface of brake pad or brake disc!)
RESTRICTIONS
Only suitable for brake system ATE!
TECHNICAL INFORMATION
Brake pads
Width [mm]: 155,1/156,3
Thickness [mm]: 20,6
Height [mm]: 66/71,3
Incl. wear warning contact
Length [mm]: 135
Brake system: ATE
Brake discs
Type: VENTED
Diameter [mm]: 312
Thickness [mm]: 25,0
Height [mm]: 49,9
Number of holes: 5
Pitch circle-Ø [mm]: 112
With screws
MAPP-Code available
Surface: Coated
Processing: High-carbon
Ok, sorry for the noob question but how do I find out what OE system I have then? Mines a 2006 mk 5 gti totally stock.
I really didn't mean any harm by posting this  as I thought you'd read the description but I'm sure it doesn't really matter as long as the diameter and thickness are the same
