Author Topic: Poor Handling  (Read 9778 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Poor Handling
« Reply #15 on: February 10, 2017, 04:09:07 pm »
Maybe adjust the roll bar setting from stiffest setting?.
If anything, reducing the rear roll bar stiffness would increase understeer even more. Stiff rear = more oversteer... theoretically.
No I mean adjust the setting to the softer one may help?.
Like I said, reducing the stiffness of a rear bar will not reduce understeer. It will increase it.
Soft rear = understeer
Hard rear = oversteer
OP is complaining of understeer. So making the rear softer won't help.
right so there's no in between lol
Re: Poor Handling
« Reply #16 on: February 10, 2017, 04:21:45 pm »
I'd really consider changing the tyres. I'm having similar issues with my C63. Currently running pilot super sports. Its a soft tyre so allows a lot of flex when cornering and traction isn't great. Previously I was running conti 5's which were great but were noisy and needed replaced.
A few owners on the merc forum have also had similar issues with pilot super sports yet some are fine with them.
I'm running pilot sport 2 or 3's on my Gti and it handles really well. Think I'll go conti 5 or eagle F1 next or maybe even uniroyal rain sport
It wont be the tyres... plenty of folk including myself have ran MPSS on the mk5 and found them to be excellent.
Offline Matto
  • -Receive: 116
Re: Poor Handling
« Reply #17 on: February 10, 2017, 04:54:57 pm »
Is the alignment definitely right? Where was it done, and on what equipment? How long ago was it done, and has anything been fitted/replaced under there since?
How much torque are you running? And is it a big lump of it at 3-3.5k, or a smoother curve? Do you have a graph of your current map?
I personally found PSS were excellent in the bends. The car still behaved like a front driver should, but they reduced understeer massively over the Kumhos that were on the previous wheels. Fantastic tyres.
I did find they'd struggle with straight line grip once they were down close to 3mm or so. Replacing them with new PS4s improved that considerably. I'm running 350lb/ft+ and still get a bit of slip in 3rd at full throttle around peak torque, but only really if it's wet or colder than around 7-8 degrees.
I won't even entertain the idea of winter tyres when in all conditions except near enough freezing a good summer tyre like the PS4 outperforms them by miles.
Last possibility... Do you think the car might ever have been in a bump?
Right so to tie up some loose ends. It hasn't been aligned for a while BUT I had it checked when the MPSS's were fitted, last year some time I think. I took with me the print out from when Alex @ AKS set it up upon H&R spring install. My mate that checked it said it was a little bit off the previous alignment but not worth messing with as it was not much different.
I am running around 350 torques but the curve is relatively smooth.
Car has never had a bump to my knowledge. I was the second owner at 10K miles.
The only other decent tyres I have had while owning the car are Hankook Ventus V12's. Now these were amazing when new with H&R's and standard dampers. Coilovers are not a option as I have no plans on keeping the car no longer than 2 years hopefully.
Offline Paradox1
  • -Given: 41
Re: Poor Handling
« Reply #18 on: February 10, 2017, 05:31:50 pm »
The inbetween is the settings on the front and rear bar to get the best handling
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #19 on: February 10, 2017, 05:55:48 pm »
@Matto If I was in your boots I'd try and get booked in with Alex again. Explain the situation, and let him have the car for a few days if he needs it. He might be able to identify the cause on the ramp or by having a drive.
As he's done work for you before I'd imagine he'd be happy to investigate it. Nothing really stands out to me as a potential major issue from what you've said. Things are often made clearer once the car is up in the air though.
  • -Receive: 692
Re: Poor Handling
« Reply #20 on: February 10, 2017, 06:14:20 pm »
I guess some cars don't get on with some tyres.  It's generally why OEMs fit a specific tyre at the factory, having done shed loads of testing.  They put the cars through things 95% of customers never would.
Pilot Sports have always worked well for me on VWs, especially the Super Sport.  Try the new PS4 S next time.  It's supposed to be great  :smiley:
350lbft in a FWD car is always going to be a challenge in the wet. I just wish the MK5 had EDL that worked above 25mph and we wouldn't have all these traction issues, or need a diff.
Offline grumpy
Re: Poor Handling
« Reply #21 on: February 10, 2017, 06:16:29 pm »
Matto,
In my opinion your setup should be a rewarding drive. All I think you need to do is fit the subframe locking kit from 034Motorsport, got mine from Awesome, it's an amazing mod.
Read the sales blurb, it does exactly what it says on the tin, chassis comes alive.
Tip....as soon as it's fitted go for a fresh alignment.
Offline Matto
  • -Receive: 116
Re: Poor Handling
« Reply #22 on: February 10, 2017, 06:18:41 pm »
It was down there a few weeks ago to have the dampers fitted so was up in the air. Was also taken out for a test drive and nothing was mentioned about how it handled etc. Unfortuneatly I am unable to leave the car there as it is my only form of transport, plus it is 1hr 45mins away so can't just nip by.
The reason I tried them as a lot of people got on with them on here so thought they were worth a go.
Re: Poor Handling
« Reply #23 on: February 10, 2017, 06:45:47 pm »
Matto,
The locking kit does nothing in terms of handling.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #24 on: February 10, 2017, 06:48:55 pm »
Are there any forum members nearby who you wouldn't mind having a drive?
I think if you can get some second opinions on how it drives you might get some insight into it.
Offline grumpy
Re: Poor Handling
« Reply #25 on: February 10, 2017, 07:12:41 pm »
Rich83,
Going from a subframe with movement to a subframe without movement will improve the handling.
I definitely felt an improvement after fitting  :happy2:
Offline grumpy
Re: Poor Handling
« Reply #26 on: February 10, 2017, 07:21:32 pm »
Rich83,
"This kit includes 12 stainless steel subframe locating collars and 6 new bolts, and can be installed in approximately one hour for a more rigid chassis and improved handling performance."
Honestly, it works  :driver:
Re: Poor Handling
« Reply #27 on: February 10, 2017, 08:42:54 pm »
Unless you are getting huge amounts of movement it won't help at all.
In mattos case it won't make a blind bit of difference.
I've got it on mine and yes it stopped most of the subframe noise but didn't do anything for the handling.
Offline grumpy
Re: Poor Handling
« Reply #28 on: February 10, 2017, 09:06:57 pm »
Rich83,
Fair comment.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Poor Handling
« Reply #29 on: February 10, 2017, 09:42:00 pm »
oops still haven't looked at my H&R properly  :signLOL:
