Author Topic: Forge Turbo Muffler Delete Pipe (EA113 KO4 Engine)  (Read 21503 times)
Offline Dave J
  • -Given: 45
  • -Receive: 63
« on: February 18, 2017, 05:33:06 pm »
Good afternoon all,
Has anyone any experience of the above part? I've not read of anyone on here having one fitted, so wonder if it is a pointless noisy upgrade? There's no mention of any performance increase other than 'improved response'.
Cheers,
Dave
Edition 30 - no. 1387
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Forge Turbo Muffler Delete Pipe (EA113 KO4 Engine)
« Reply #1 on: February 19, 2017, 09:08:02 am »
Buy the chinese boost pipe kit from ebay for around £120. Comes with a silencer delete pipe, charge and throttle pipes. Much better value. The part on its own will make no real difference
  • -Receive: 692
« Reply #2 on: February 20, 2017, 09:56:33 am »
Along with an S3/6R intercooler and a modified discharge pipe (standard end cut off and replaced with a 2.25" rolled end), the forge part is a good way to delete the final O ring connection.  On it's own, zero gain.
If you still have the standard intercooler and leaky O ring connections, you might be surprised how different the engine feels after doing that.
Out of curiosity, I tried one of those aftermarket KO4 'hi flow' discharge pipe with muffler delete kits and was so underwhelmed, I sold it on immediately.   The factory parts are very good.  You just need to shift the O rings and get all of the boost instead of some of it.
  • -Receive: 692
« Reply #3 on: March 31, 2017, 05:52:59 pm »
Just an update to this. I've fitted the Forge muffler delete and the modified discharge pipe. I now have zero bayonet connections and it drives all the better for it and no more oily patches on the under tray.  Definitely worth doing this  :smiley:
There is no extra noise from the forge muffler delete.  Maybe it only affects K03 turbos?
From this:
To this:
Offline Richie-VRS
« Reply #4 on: April 07, 2017, 05:52:32 pm »
A bit off topic but should there be some kind of seal in behind the muffler on the turbo? I took mine off my new turbo and didn't see one
  • -Receive: 692
« Reply #5 on: April 07, 2017, 08:00:12 pm »
Yep, there is an O ring in the compressor housing to seal the muffler. Part no. WHT006482.  74.8 x 1.65mm O ring.
They're on back order from Germany as I need a new one.  Mine's squished flat a bit.
Surprised yours is boosting OK without one!
  • -Receive: 692
« Reply #6 on: April 08, 2017, 10:12:02 am »
Before you order one, I took the seal out of my TTE420 to use on my KO4 in the meantime and noticed it's a bigger seal than I said above.  85mm diameter.
But you can see there definitely is a seal there, in KO4s at least.  KO3s may be different?
Offline Richie-VRS
« Reply #7 on: April 08, 2017, 10:20:09 pm »
Thanks pudding, I've not fitted my k04 yet but when I took the muffler out there definetly isn't a seal there, there is a cut out for the seal to sit in which is why I was wondering.
I'll go to Audi at some point and order one along with the diverter valve mounting flange and a few other random bits.
It's odd that my "brand new" second hand turbo is missing the seal  :thinking:
  • -Receive: 692
« Reply #8 on: April 13, 2017, 02:48:07 pm »
I can confirm the part number I quoted for the seal is for a K03 turbo!
RE your KO4 missing it's seal, well that is just weird, but I guess humans can forget things sometimes!
Offline Richie-VRS
« Reply #9 on: April 16, 2017, 10:59:48 am »
The turbo is technically second hand and had a broken n75 valve so I suspect foul play by the previous owner!
I'll need to get a seal ordered as my boost pipes have arrived in Glasgow from china eventually so will be delivered by Wednesday!
Offline spesh
« Reply #10 on: April 16, 2017, 11:15:29 am »
http://www.ebay.co.uk/itm/EPMAN-TURBO-PIPING-KIT-ALUMINUM-BOOST-PIPE-FOR-VOLKSWAGEN-VW-GOLF-GTI-MK5-6-2-0T-/142243156208?fits=Plat_Gen%3AMK+V&hash=item211e5a50f0:g:W6IAAOSw241Yd7WU
This one?
Offline Richie-VRS
« Reply #11 on: April 16, 2017, 04:00:00 pm »
These ones mate 261675948859.
Think they took my offer at £120, only problem I have is that I ordered them on the 1/3/17 and that's me just getting them.
I don't think they even sent them the first time. Had to pay £24 customs on top of the £120 too but sill much cheaper than uk suppliers.
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,63938.0.html
« Reply #12 on: June 05, 2017, 06:39:56 am »
Richie-VRS did you find part number for K04 seal between turbo and muffler?
Offline Richie-VRS
« Reply #13 on: June 05, 2017, 09:04:01 pm »
Sadly not as of yet. I spoke to Cardiff audi on eBay as I was buying bits from them anyway, they say it's not available separately however I'm not sure if they just couldn't find it as it seems odd that an o ring isn't available.
I've not been into my local Audi yet.
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #14 on: June 07, 2017, 06:34:44 pm »
If someone have spare one can mesaure it and then you can get it in store with o-rings... If we get dimension will help a lot...
