Author Topic: Do you need heat shield with induction kit?  (Read 4336 times)
Offline jaylufc17
  • -Given: 48
« on: April 08, 2017, 08:33:39 am »
I've got a ram air induction kit on my mk5 GTI...
As per one of my previous posts I've had the issue of the cone rubbing on what I believe is the coolant pipe... so to stop this managed to play around with the set so the cone just clears the pipe now...
Next problem the heat shield is now very tight rubbing on the 90 degree silicone pipe...
Thinking to just take the heat shield off... advice please....
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: Do you need heat shield with induction kit?
« Reply #1 on: April 08, 2017, 09:06:50 am »
Those Heatshield you get with the ram air are useless anyway. Loads of gaping holes everywhere. If you wanna keep it on then a bit of padding or sponge on that corner of the silicone pipe with a cable ties round it will protect it.
Or remove it as shouldn't make that much difference as as said it's not completely enclosed.
Better ones are fully enclosed and only allow cooler air to get to the filter.
Offline jaylufc17
  • -Given: 48
« Reply #2 on: April 08, 2017, 10:18:46 am »
 Cheers, I've taken it out lol that's what I was thinking don't seem of any use to me
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 79
« Reply #3 on: April 08, 2017, 11:51:54 am »
I have a ramair on mine and everything fits perfectly, just have to adjust accordingly, the silicone hoses are easily adjustable. Even though the heatshield is "useless", personally I think it finishes of the kit nicely
Offline jaylufc17
  • -Given: 48
« Reply #4 on: April 08, 2017, 01:07:43 pm »
Haven't got the patience lol been trying for weeks now
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: April 08, 2017, 10:40:02 pm »
Undo the other end of the hose and push it in further takes seconds  :signLOL:
Offline flashp
  • -Receive: 65
« Reply #6 on: April 10, 2017, 09:31:40 pm »
I'd say no to a heat shield being required, but a better intercooler to deal with the heat is a sensible proposition. This sheds heat in the inducted air.
Saving a few degrees on intake air to have it heated by the turbo is academic almost in a forced induction motor, different story in a naturally aspirated.
Gone but not forgotten :-)
