Author Topic: MK6 clocks into MK5 - ABS Pump  (Read 40506 times)
Offline shoaybmakda
  • -Receive: 54
« on: May 08, 2017, 11:43:38 am »
Hi all
I have recently purchased some mk6 clocks to fit into a mk5 golf Gti.
I've been told however that the ABS pump may need updating. I haven't checked yet what version I have but as it's an 05 plate I'm going on the premise that it will need updating.
I have read that the version Q is the one to go for - are these pumps hard to change and is there any how to's available? And is the below part all I would need?
http://m.ebay.co.uk/itm/162501280194?_trksid=p2060353.m1438.l2649&_mwBanner=1
Offline Cr33D
Re: MK6 clocks into MK5 - ABS Pump
« Reply #1 on: May 08, 2017, 12:39:42 pm »
You would need BE pump. Apart from that you need a bracket for it and brake pipework for a front wheels as in mk60ec1 are opposite to mk60. Additionally some rewiring / pin out changes on pump loom plug. I can pist a parts lists later on if interested.
Sent from my EVA-L09 using Tapatalk
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: May 08, 2017, 01:55:13 pm »
Can someone also confirm if newer Can gateway and MK6 Golf steering wheel is needed as well?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #3 on: May 08, 2017, 02:43:18 pm »
No need for a newer steering wheel, at worse you'll need to upgrade the steering wheel module for the CH revision.
Offline Cr33D
« Reply #4 on: May 08, 2017, 05:23:37 pm »
I had already newer Gateway and CH Steering module before doing an ABS swap and clocks swap, so not 100% sure. With newer clocks TPMS is done via cluster hence might need a gateway swap for a newer one.
List of parts:
1K2 614 235 C Pump bracket 1
1K0 614 235 D Pump bracket 2
1K2 614 723 F Brake Line left
1k2 614 724 M Brake Line right
About pumps: (pick one depends on the functions you want to have)
ESP, XDS, HHC - 1K0 907 379 (AJ/ AT/ BE/ BJ/ BL)
ESP, XDS, ---- - 1K0 907 379 (AH/ AS/ BD/ BH/ BK)
ESP, ----, HHC - 1K0 907 379 (AE/ AP)
Wiring modification:
Regards
Cr33D
Offline shoaybmakda
  • -Receive: 54
« Reply #5 on: May 08, 2017, 08:33:47 pm »
I've just checked and I have a Q revision module - 1k0 907 379 Q
Would this module be okay to install a black and white cluster?
The clocks that I am looking to fit are from a golf plus
« Last Edit: May 08, 2017, 11:38:07 pm by shoaybmakda »
Offline Christiank
  • -Receive: 39
« Reply #6 on: May 09, 2017, 09:22:16 am »
From what years is your mk5 build?
I think mk5 gti's that was build efter 8/2006 (MY2007) has an ABS unit that will work with the newer clusters.
Offline shoaybmakda
  • -Receive: 54
« Reply #7 on: May 09, 2017, 09:32:48 am »
@Christiank my car is a 2005 build I think but it is registered as a 2007 as it is an import back into the UK from Dubai.
I read this thread which says it should be ok but I've been told by Alex that it's too old:
http://www.mk5golfgti.co.uk/forum/index.php/topic,93520.15.html
Offline Christiank
  • -Receive: 39
« Reply #8 on: May 09, 2017, 09:34:48 am »
I think the Q version is fine? I have a MY2005 car with the "K" so I did the Mk60 to Mk60ec1 swap :)
didn't know that the Q revisions was fitted from that early on.. Good to know.
I think my mates GTI also has the Q version and he didn't have to change anything.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #9 on: May 09, 2017, 11:34:51 am »
No the mk5 need to be MY2009, so they have to have been built after 08/2008, like my GT Sport. My Ed. 30 is a MY2008 and still has the MK60 ABS pump.
My GT Sport came with a Q rev CAN Gateway and my Ed. 30 had a L rev CAN Gateway.
Offline shoaybmakda
  • -Receive: 54
« Reply #10 on: May 09, 2017, 12:09:56 pm »
I've spoken to Eddie NL who has advised my abs pump is okay to go with
So no idea what to do with it now?
My dilemma is Eddie is 3 hours away from me and my current situation is I can't take 3 hours out of my day to get to him.
Alex on the other hand is 45 mins away but he's advised my pump is too old!
« Last Edit: May 09, 2017, 12:11:41 pm by shoaybmakda »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #11 on: May 09, 2017, 12:17:00 pm »
Can you confirm that Eddie knows that your ABS pump is a MK60 and not a MK60EC1? Maybe he confused the part number...
Offline shoaybmakda
  • -Receive: 54
« Reply #12 on: May 09, 2017, 12:29:29 pm »
@Shoduchi how do you check which one it is?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #13 on: May 09, 2017, 12:34:19 pm »
With a VCDS scan of the ABS module.
Offline Christiank
  • -Receive: 39
« Reply #14 on: May 09, 2017, 01:14:32 pm »
you can still make it work with a Mk60 unit if the electronic module is newer than the "K" revision I think - There's a few thread on the internet about it you search for it.
That way you'll don't need to change the pump and brake pipes.
