Author Topic: Easiest Way to Access Canbus?  (Read 3698 times)
Offline JTI
  • -Given: 19
« on: May 22, 2017, 09:43:47 pm »
Hi, I need to upgrade my canbus to work with my new stereo and I understand mine is above the accelerator pedal. There's no chance I'm getting my shovel hands up in the gap to change this so are there any other ways to access? I heard of someone going via the wipers? Also could you remove the lower drivers side dash to get to it? Thanks.
 :thinking:
  • -Receive: 453
Re: Easiest Way to Access Canbus?
« Reply #1 on: May 22, 2017, 09:46:32 pm »
What year is your car?
Later models had the canbus behind the cubby box...
willni
« Reply #2 on: May 22, 2017, 09:48:08 pm »
willni
« Reply #3 on: May 22, 2017, 09:49:32 pm »
Accelerator pedal and cubby box are the same one  :smiley:
Offline JTI
  • -Given: 19
« Reply #4 on: May 22, 2017, 09:55:10 pm »
http://www.r32oc.com/topic/29242-canbus-gateway-location-removal/
There you go, wiper access route
Hmmm 15 mins? That sounds just the trick, thanks. I guarantee it will be more like 6 hours with my luck with this type of thing :)
Offline SI-R32
  • -Receive: 126
« Reply #5 on: May 22, 2017, 09:58:29 pm »
I didn't realise I'd written 15 mins lol but if your wipers come off easy and your good with the tools 30 mins max
Offline JTI
  • -Given: 19
« Reply #6 on: May 22, 2017, 11:34:20 pm »
^I guarantee I will either break my wipers, fingers, windscreen, or all three...or succeed in the dismantling only to find the canbus wasn't even located there  :grin:
Offline SI-R32
  • -Receive: 126
« Reply #7 on: May 22, 2017, 11:37:39 pm »
what year is your car as it can be there, or above the clutch peddle area or worse case I have heard of it under the ashtray which is near the Airbag module.
Offline JTI
  • -Given: 19
« Reply #8 on: May 22, 2017, 11:45:13 pm »
2005 DSG, will try stick my head up tomorrow to check.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: May 23, 2017, 09:32:03 am »
I find the cubby one easier than above clutch pedal. I go in from the cubby drawer, remove it, move the relays to the side by releasing them from the tabs, and then the canbus is straight ahead. Pull it back towards you, undo the red plug and then swap over with new and then reverse of removal. In my opinion I think it'd quicker than wiper motor route.
Sent from my SM-G928F using Tapatalk
  • -Receive: 692
« Reply #10 on: May 23, 2017, 10:03:58 am »
Wiper method for me too, especially if fitting a Polar FIS.  There's no way I was getting my hands up behind there either.
No way 15 mins.  30 is pushing it as well even for expert level who's done it a few times.
Offline Trow81
« Reply #11 on: May 23, 2017, 04:03:55 pm »
Did mine through the cubby 20 mins with a lot of swearing and finger crushing but done wasn't aware of the wiper way mines an 57 ED30
Offline spesh
« Reply #12 on: May 23, 2017, 07:44:27 pm »
wish i knew about the wiper route when I did mine
Offline JTI
  • -Given: 19
« Reply #13 on: May 27, 2017, 04:57:38 pm »
Had a poke around today trying to find this. Couldn't see anything obvious when poking around under and around the cubby/pedals. Checked it wasn't by the ashtray and it didn't seem to be. Looked again above pedals and did see some kind of red connector in the distance so gonna assume it's there and have a proper look via the wiper.
