Author Topic: Brakes feel spongy  (Read 3254 times)
Offline Lucastheone92
Brakes feel spongy
« on: May 27, 2017, 08:22:54 am »
Good morning.
My brakes have felt pretty crap since I've had the car and the pedal seems to go down quite far.
As far as I'm aware the brake fluid has never been changed (07 gti) and I can't see any leaks.
It's booked in for brake service. Would this help?
Offline FJ1000
  • -Receive: 48
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101205.0.html
Brakes feel spongy
« Reply #1 on: May 27, 2017, 11:00:12 am »
Yep sounds like you have air in the system.
While you're at it, may as well replace the fluid with some better stuff than OEM (I.e. Higher boiling point). ATE typ200 is a good economical upgrade (used to be called super blue).
« Last Edit: May 27, 2017, 11:22:38 am by FJ1000 »
2007 Golf Gti DSG | Leather Wingbacks | Xenons | VWR Springs | Tinted Windows | 18" Audi Speedlines |
Re: Brakes feel spongy
« Reply #2 on: May 29, 2017, 06:37:14 pm »
Ok thanks.
Should I replace the hoses for some braided ones or is not worth it if im not tracking my car?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #3 on: June 06, 2017, 10:10:12 am »
You shouldn't feel much difference if you don't heat your brakes a lot. Keep it simple if you don't push the car that hard. :wink:
