Author Topic: Cam chain  (Read 8627 times)
Offline mkmg76
Cam chain
« on: July 10, 2017, 04:33:55 pm »
Has anyone used the ebay cam chain kits from Germany?
They've been recommended to me by a mechanic mate but just want to double check quality/longevity if anyone has used them.
In particular i'm talking about this type of thing :
http://www.ebay.de/itm/Nockenwellenversteller-Rep-Satz-Audi-VW-Skoda-Seat-2-0-FSI-TFSI-06F109088J-G-C-/201690732631?epid=711433413&hash=item2ef5b45857:g:UEMAAOSwcgNZGfAJ
Cheers for any feedback :happy2:
Mick.
Offline Alex Rhys
Re: Cam chain
« Reply #1 on: July 11, 2017, 07:13:45 am »
  • -Receive: 692
Re: Cam chain
« Reply #2 on: July 11, 2017, 09:12:50 am »
Mick.
Anything that isn't genuine is a gamble in terms of lifespan, so it's hard to comment really.
I would only fit cheap pattern parts to a car I was shifting on.  Genuine only for my keepers.
Offline GTIEagles
Re: Cam chain
« Reply #3 on: July 11, 2017, 10:27:14 am »
Mine has had a Febi Bilstein kit on for nearly a year now and it's all been fine. Their timing chain kits are highly rated.
  • -Receive: 692
Re: Cam chain
« Reply #4 on: July 11, 2017, 11:13:06 am »
I'd be interested to see if a Febi or other pattern kit lasts 100K miles, which is when I had to do mine on the Eddy.
Offline barelyrelevant
Re: Cam chain
« Reply #5 on: July 11, 2017, 08:05:03 pm »
Aren't Febi cheap crap with a bad reputation (for suspension parts at least) ?
Offline GTIEagles
Re: Cam chain
« Reply #6 on: July 11, 2017, 11:50:49 pm »
They carry a 100k, 5 year guarantee so can't be all that bad. I doubt the genuine parts are guaranteed for that long!
Offline mkmg76
Re: Cam chain
« Reply #7 on: July 12, 2017, 11:06:34 am »
Thanks for input all, I've decided with engine critical components to go the genuine route with the chain kit. Not doing the cam adjuster at the moment so there's not that massive expense.  :happy2:
Offline ducman77
  • -Given: 59
Re: Cam chain
« Reply #8 on: July 12, 2017, 11:12:43 am »
Best of luck with this mkmg76 :laugh:
Will be keeping a close eye on your progress and giving you marks out of ten  :laugh:
Regards,
Dave
  • -Receive: 692
Re: Cam chain
« Reply #9 on: July 12, 2017, 11:46:55 am »
You don't need the VVT adjuster unless it gets damaged from removing it's bolt.  It's a silly little posidrive type head that rounds out VERY easily, so be careful!
Offline mkmg76
Re: Cam chain
« Reply #10 on: July 13, 2017, 11:19:35 am »
Regards,
Dave
Cheers Dave, you can pop round and make the tea if you like!  :happy2:
Cheers, I've read exactly that on a few threads so I asked VW to get me the correct tool while ordering the parts to (hopefully) lessen the chances of anything disastrous happening.
  • -Receive: 692
Re: Cam chain
« Reply #11 on: July 13, 2017, 12:00:47 pm »
Regards,
Dave
Even with the VW tool, the only way to prevent it stripping out is with an impact gun, or getting someone to press hard onto the socket whilst you undo it, otherwise it will just strip out.  The recess for the toolbit is just way too shallow.  A nice long breaker bar required.  The torque needed to crack that bolt off is insane, considering it's only tightened to 40lbs or something low like that.  Genuine cam lock tool as well.  Cheap ones bend too much.
Offline mkmg76
Re: Cam chain
« Reply #12 on: July 13, 2017, 12:08:27 pm »
Regards,
Dave
Ok, so you reckon an impact gun is the way to go? Last thing I would've thought if its soft but I can understand getting it out with one shock movement rather than letting it slip after a few attempts and rounding the head. I have a Snap-on battery impact gun that I can use on it.  :happy2:
  • -Receive: 692
Re: Cam chain
« Reply #13 on: July 13, 2017, 12:15:59 pm »
Regards,
Dave
Yeah, I didn't use that method on mine, but it crossed my mind whilst pooing my pants with the 4 foot breaker bar that impacting it might be better..... that way you can do it solo and press hard onto the bolt at the same time.  Less bending going on with the cam lock tool as well.  I dunno, I'd be interested to hear from the pros how they get the bolt off!
Offline mkmg76
Re: Cam chain
« Reply #14 on: July 13, 2017, 12:18:47 pm »
Regards,
Dave
Haven't seen the bolt yet obviously, what head is on it? Just a posi +  or is it splined?
