Author Topic: Engine tapping/ ticking noise. Video enclosed  (Read 7531 times)
Offline Dave_d
« on: July 16, 2017, 04:50:23 pm »
Hi guys. Does anyone know what could be causing this ticking/tapping noise?
Thank you
Offline Dave_d
Re: Engine tapping/ ticking noise. Video enclosed
« Reply #1 on: July 17, 2017, 10:48:36 am »
No one?
Offline Ripstop
« Reply #2 on: July 17, 2017, 12:19:45 pm »
Ok so I am not expert but since I changed my cam chain on my Eddie I am paranoid about noises.  Changing the chain solved my issue but it didn't sound like your noise. Things to check.. N80 evap purge valve does make a ticking a little like that, all the GTi's do but some can be louder than others and its normal. Its at the front of the engine on the right as you look at the engine. It doesn't sound like injectors either as they are more a background level of ticking.
Hold the valve or use a screwdriver to touch the body and see if the timing is the same as the noise.
Check this link here to see where it is http://www.golfmkv.com/forums/showthread.php?t=119267
Something else to check is the fuel pump but I have a feeling if its doing that then you could have a problem as they don't tick! Finally can you get anyone to check for any DTC's using VCDS to verify no errors? If there aren't any I would suggest you could just live with it?
Rip.
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
Offline Guy123
  • Newbie
« Reply #3 on: March 31, 2022, 08:41:06 pm »
Did you sort/find out what this ticking noise was?
Offline Awisko
« Reply #4 on: November 13, 2024, 04:58:02 am »
did you ever end up solving this? my gli with 250k km sounds exactly the same as this
Offline ZoliWorks
« Reply #5 on: November 14, 2024, 09:24:04 am »
Sounds like a failing/failed N80 EVAP valve. If you put your hand on it and it's vibrating or it's making this ticking sound, replace it.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline mjmallia
  • -Receive: 60
« Reply #6 on: November 14, 2024, 09:44:44 am »
Rattling cam chain due to wear of the tensioner etc or a broken seal ring in the casing to me
Mike
South Coast
