Author Topic: Intercooler pipe  (Read 3954 times)
Offline Shamm
Intercooler pipe
« on: August 23, 2017, 01:31:00 pm »
Does anyone know the part number for the passenger side intercooler pipe which is common for leaking oil. And would anyone know the price?
Thanks in advance
Offline Paradox1
  • -Given: 41
Re: Intercooler pipe
« Reply #1 on: August 23, 2017, 02:42:57 pm »
not sure of the part number but im sure if you ask nicely someone on here with an upgraded intercooler will sort you out with there hold hoses.
Its usually the rubber O rings in the intercooler hose that fail rather than the actual hose
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #2 on: August 23, 2017, 05:04:47 pm »
Agreed that mostly it is the o-ring that needs replacing rather than the hose. The pn is: 3C0-145-117-F
The clips are available as well. 1J0-145-769-B
« Last Edit: August 25, 2017, 09:24:47 pm by ROH ECHT »
Offline Shamm
« Reply #3 on: August 24, 2017, 01:14:14 pm »
Thanks for the response, i took off the hose and the clips that its meant to hold onto the intercooler one of them have sheard off but the o rings look fine. And the oil is all over the pipe and im still not sure how that oil has got up under the engine cover maybe it got blow there with the leakimg boost pressure lol im not sure though
Offline Shamm
« Reply #4 on: August 25, 2017, 11:05:30 am »
Part number for anyone that needs the hose: 1k0145834am
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #5 on: August 25, 2017, 09:26:33 pm »
If oil is escaping at the connection...the o-ring is likely not OK.
Offline Shamm
« Reply #6 on: August 28, 2017, 09:40:04 am »
Yeh iv changed the pipe and o ring but i getting abit of lag
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #7 on: August 29, 2017, 01:14:18 am »
Have you logged boost data in the past and can you do a recent log?
Offline Shamm
« Reply #8 on: September 01, 2017, 12:45:13 am »
Nah no access to a vcd im gona see if i can find someone hopefully
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #9 on: September 01, 2017, 06:24:56 am »
Your DV may be shot.  :confused:
Got a boost gauge?
Need to look at your boost and wgdc data...may need to look at your error codes as well. I'll keep checking in here for updates.  :drinking:
Offline Shamm
« Reply #10 on: September 03, 2017, 02:56:50 am »
Nah doubt the dv gone cuz i put a gfb dv   :mad: but i was reading somewhere the bolts can get loose but i did use threadlock however when i get time iam going to take engine cover off and look at the pcv piping while the engine is runiing to see if any oil is leaking from a cracked pipe maybe  also i dont have a gauge :signLOL:
