Author Topic: MK5 GTI track Slag  (Read 15491 times)
Offline vag
MK5 GTI track Slag
« on: September 10, 2017, 07:48:37 pm »
Hello all, thought it start a build thread on my GTI
I bought it from a police auction with no keys/history didnt even see it just pictures, when it turned up it was much much worse than the pictures made it out to be. The car has had a very hard life and OSR 1/4 was full of filler, paint all round was in very poor condition. So there was no point me putting it back on the road as a normal car!
This is how it was dropped off, xenons where so badly bodged iv never seen anything like it. Twisted wired, news paper holding the bulbs in place!
look at this beauty!
So basically sold the interior and all the bits i didnt need, which actually returned a healthy sum!
Made a harness bar, it mounts to factory mounts at the back, didn't want to make anything to permanent as i will get a cage eventually.
Mounted my seat and harness
Removed anything that wasn't needed anymore!
Had some metal laying around in the workshop, so made a X brace to bolt to the old seat belt points. Not structural what so ever but probably helps a tiny bit.
My favourite mod so far, hole sawed the dash to fit mk1 VDO gauges!
Oil temp sender from a mk2 16v mounted to a sump plug.
Wired up and working, pressure gauge also works now, had to use a remote pressure sender.
Made a blank for the stereo.
Fitted a boost gauge
BC coilovers fitted!
Probably does nothing, but a bit of OE aero from an A3
« Last Edit: October 18, 2017, 10:27:25 pm by vag »
Offline vag
Re: MK5 GTI track Slag
« Reply #1 on: September 10, 2017, 08:19:37 pm »
My first ever track day was awesome, car performed faultlessly.
Second track day at brands was going well until last 10 mins of session when i hit a patch of oil where a Clio blew its gearbox, i ran out of talent and kissed the wall.
look at the filler!
So now the annoying part, i replaced the rear 1/4 with a genuine one, the state of that panel was why it became a track car in the first place :rolleye: so now its a better car after the crash!
Running gear wise it only bent the hub :)
£39 wing from euros  :signLOL: will eventually go wider at the front!
New inner tub and 1/4 in place
Got a bit carried away!
Friend lent me his body shop for the weekend, paints not perfect but Racecar!
Fitted back up
Was back on track 3 weeks after the crash   :happy2:
My fastest lap was 58.01 which i was happy with  :happy2:
« Last Edit: October 18, 2017, 10:28:06 pm by vag »
Offline Rigsby
  • -Given: 22
« Reply #2 on: September 10, 2017, 10:20:36 pm »
Respect for getting in fixed so quick, looking good.
Did you get the wings from Euro car parts? What's the fit like?
Offline Paradox1
  • -Given: 41
« Reply #3 on: September 11, 2017, 12:14:16 pm »
Nice build,
What tyres are you running? they look like semi slicks
Offline Rigsby
  • -Given: 22
« Reply #4 on: September 11, 2017, 02:53:26 pm »
Nanking ns2r
Offline vag
« Reply #5 on: September 11, 2017, 02:58:56 pm »
Nanking ns2r
Indeed your're correct.
The wing is ok, not very well made but after a little bit of fettling it was alright. I'd go genuine though if i was you, only reason i used it was because i want wider front eventually.
Offline Paradox1
  • -Given: 41
« Reply #6 on: September 11, 2017, 04:50:57 pm »
How do you find the tyres? Im thinkin the nankangs or federal 595 for both road and track
Online FJ1000
  • -Receive: 48
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101205.0.html
« Reply #7 on: September 11, 2017, 05:25:59 pm »
Nice!! Looks a great project.
Out of interest, did you weigh the stuff coming out of the car, or have an idea how much the car weighs now?
What else do you have planned? I'm sure a map and brake upgrade would pay big dividends on track.
2007 Golf Gti DSG | Leather Wingbacks | Xenons | VWR Springs | Tinted Windows | 18" Audi Speedlines |
Online FJ1000
  • -Receive: 48
« Reply #8 on: September 11, 2017, 05:31:18 pm »
I've got NS2R's on my track TT and I'll warn you now - they're horrible in the wet! Even with haldex. Ended up buying another set of wheels to mount some continental sport contact 5's onto (which are excellent in the rain) as a "wet" setup.
Excellent in the dry though, as are the federals. Very grippy on a dry track.
Offline vag
« Reply #9 on: September 11, 2017, 06:20:50 pm »
 :happy2: I should of weighed everything, there was so much. I even unpicked all the redundant wiring, so the only wires left going to the back are for lights and demister. Door control modules are gone, hard wired the motors in with a basic switch on each door, so only 2 wires in each door. Anything to do with airbags are gone, bottom of the dash is all cut out. Spot weld drilled any bracket that are no longer needed, complete AC setup gone, Every trace of sound deading gone.
Not much more left i can get rid of! unless i start hole sawing things!  :signLOL:
Offline vag
« Reply #10 on: September 11, 2017, 06:23:16 pm »
Love them, but i haven't tried any other semi slicks to compare them against.
My friend runs them on his daily GTI, im sure come winter they will get hairy though.
Offline Paradox1
  • -Given: 41
« Reply #11 on: September 12, 2017, 09:34:00 am »
Thanks fore the feedback.
Yeah I can understand a semi slick wouldnt be great in the rain but then again I try not to drive lively in the rain for obvious reasons.
Currently on goodyear egale f1 which seem decent for a road tyre
Offline Octoparrot
  • -Receive: 102
« Reply #12 on: September 12, 2017, 12:44:38 pm »
Interesting read and nice work, just curious as to why you didn't mount the gauges in the radio blanking panel?
Offline GTIEagles
« Reply #13 on: September 12, 2017, 02:08:02 pm »
Great work, could extra weight be saved by removing the dashboard too? Or are the electrics too reliant on that being there?
Offline vag
« Reply #14 on: September 12, 2017, 07:49:41 pm »
Originaly i was going to mount a tablet there via OBD link, but i found it slow and annoying as it had a second or so delay.
You can clearly see them from my seat anyway :)
