Author Topic: Coolant Fault Codes  (Read 2134 times)
Offline norman1979
Coolant Fault Codes
« on: February 09, 2018, 02:20:27 pm »
I have two fault codes which are turning my EML light on:
P2600 Coolant Pump Control Circuit: Open
p2185 Engine Coolant Temp Sensor on Radiator Outlet - Signal too high
Does anybody know if these are linked error codes? I know where the temp sensor is, but where is the Coolant Pump sensor?
  • -Receive: 692
Re: Coolant Fault Codes
« Reply #1 on: February 09, 2018, 04:02:21 pm »
I think the engine ECU toggles a relay for the electric water pump, so it might be complaining about that circuit.   Check to see if you get 12V at the pump connector.
